Denon receiver If it's the preamp how do I remedy?
  • 19,396 Answers
Well I do not know how is on your model, usually it is all on the same mainboard. if its transistors you change the transistors , or there may be a thermic swithch that turn system off.
You should also consider that may be a fault on some of the control chipset.
A problem of this kind won't be an easy DIY unless you have a good background.
I do not have diagrams or schematics for your model, If I find some, I will send them tomorrow.
Leave your denon unplugged overnight, place it away from other devices, until you fix the problem.
Give me your location if you also need directions for local service support.
I will post back tomorrow
Posted on Apr 05, 2008
Left speaker channel sound intimitent
It may be as simple as a dirty volume control, Some contact cleaner will remedy that. but it may also be as time consuming as finding a bad solder connection. If it drops out with headphones on, suspect the volume control area and the preamp section of the amp. If it just drops out with the speakers, but not the headphones- look at the connections around the output transistors. If nothing is apparently broken, and solder joints are sound or reflowed with no change, get a can of "component chiller" and spray each output transistor of affected chennel, and the electrolytic capacitors in the finals and driver stages until it corrects and then replace defective part, though i suspect a bad solder joint to be more likely.. .
Oct 29, 2012 | Sony Audio Players & Recorders
Broken display on PT3300
mine came in the mail today and it did that already so i hope it is'nt that
Feb 25, 2012 | Pyle Pt3300 Amplifier
Remote Control for my Adcom GFP-715 Preamplifier does not control volume consistently. When I turn up the volume with the remote the motorized volume control will not stop turning it up until it reaches...
Hi Douglas...
w/o seeing the unit , I would try soaking the remote ( without batts in it) in a ziplock bag of isopropyl alcohol for a couple hours . Shake it up a bit too.
Let it dry out for a day before trying it again
Also, are the batteries in the remote new?
Nov 09, 2009 | Adcom GFP-715 Amplifier
Right half of my speaker inputs on the sub do not send signal
If both speakers work on one side and do not work when put on their respective sides, this indicates that the amplifier needs to be serviced.
You will have to give the amplifier/receiver to a service center to have it repaired. Ask for an estimate. These repairs may not be low in cost.
Jerry G.
Jul 20, 2009 | Audio Players & Recorders
CROWN CE 1000
Is it clipping for real or overheating ? It may just be a fault with the indicator light circuitry itself. Make sure the input levels of the amp are matched with the output levels of whatever device is running into the amp, they will either be +4 dbm or -10 dbu, if you have a choice you want them to be set at +4 dbm. Crowns are professional amplifiers and withstand years of hard touring on the road, it would definitely be worth it to take it to a good repair shop if you can't remedy the problem yourself.
Jul 26, 2008 | Crown CE2000 2-Channel Amplifier
Cyber twin v 1.2
Problem sounds like micro-processor in erratic. Unplug unit for 24 hours then try again. If this does not remedy, problem is in processor, take in for service
Apr 28, 2008 | Audio Players & Recorders
Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Dan
Apr 05, 2008 | Denon AVR-3805 Receiver
No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Apr 22, 2007 | Sony KV-27V22 TV
44 people viewed this question
 Grubhead
Grubhead
