Question about iRobot 5800 Scooba Vacuum
Scooba My scooba is not holding a charge. It will run for about 10 to 15 minutes and stop. What can I do? It is less than 4 months old.
    Problem Solver:
  • 8 Answers
Sorry to say, but you have a bad battery. If it's still under warranty, call them and they should replace it. If not, you'll need to buy a new one.
Posted on Feb 24, 2009
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    Scooba 5800 starts to charge then beeps loudly
    1) test the batteries very well in another device.
    2) test the charges if working properly.
    3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
    God bless you
    Sep 19, 2012 | iRobot 5800 Scooba Vacuum
    Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
    Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
    Aug 10, 2010 | iRobot 5800 Scooba Vacuum
    Scooba now stops sooner and isn't finished cleaning :-(
    I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
    Hope this helps.
    Jul 17, 2009 | iRobot 5800 Scooba Vacuum
    Scooba says check tank and won't move.
    Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
    Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
    Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
    May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
    Scooba won't turn on
    It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
    May 08, 2009 | iRobot 5800 Scooba Vacuum
    Scooba not working after full recharge
    NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
    Apr 08, 2009 | iRobot 5800 Scooba Vacuum
    Scooba 5800 Power button Red Blinking
    You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
    Aug 06, 2007 | iRobot 5800 Scooba Vacuum
    Scooba doesn't put watter. Pump not working?
    I calledthe company and they told me to forcefully flush warm water repeatedly through the valve that is just  above  the brush release button the the mechanical part  of the scooba.  It may take 20 or 30 flushes (I used a turkey baster, iRobot suggested a children's nasal syringe) and "Scooby" is  running great.
    Jul 28, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
    iRobot 5800 Scooba Vacuum Logo
    278 people viewed this question
    Top iRobot Vacuums Experts
    Shehu Pro
    Shehu Pro
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
