My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool So I do not think this is a heat problem.
  • 3,037 Answers
It is shutting down itself because of a crossed wire in the speaker
Posted on Apr 05, 2008
    Genius:
  • 1,665 Answers
This is power supply weakness.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 05, 2008
    Power supply can not produce the current needed when volume is increased at high level. It must be checked and repaired by an authorized electronic repair shop.
    When repair done leave a new post about what caused the problem.
  • 19,396 Answers
The preamp is overheating, if it was the piwer supply woldn't depend on volume.
    Genius:
  • 3,422 Answers
Try a hard reset first unplug all the cords from the ck and allow the unit to reset for 30min and then plug in the cords back.
I will be posting more troubleshooting steps..
Goodluck..
Itunes and Spotify crash when connected to denon reciever
Yes it sound like you have a fault on the power amp section. Perhaps a faulty transistor? It might be difficult to sought out, unless you have a bit of experience in tracking down these types of faults.
Jun 10, 2017 | Audio Players & Recorders
Power indicator is flashing after volume spiked and unit shut off
You can try a hard reset: Unplug unit from AC mains and remove all cables from unit . Wait about 3 hrs and replug to AC power and redo the cabling. Switch on the unit and see if it works..
Sep 26, 2008 | Denon AVR-1082 Receiver
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Dan
Apr 05, 2008 | Denon AVR-3805 Receiver
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
110 people viewed this question
 Grubhead
Grubhead
