Question about Palm TX Handheld
Screen corner insensitivity
Hello, since a while my screen does not respond in the top left corner and when I draw on Note, lines are shifted around this corner. I didn't try the hard reset yet thinking that maybe there will be a possible solution. Maybe a software problem : when I calibrate, it accepts the top left target. However, this target is upper the insensitive zone.
can you help ?
Regards
David
    Scholar:
  • 125 Answers
Screen drift is a common problem on Palms and there are many forums about it. First, make sure it is not your screen protector. This is a common culprit. Also, make sure ther is no dirt between the screen edges and the case. Running a folded piece of paper in between can clean it. I worked on a friends Palm with this problem and the solution was third party software called PowerDigi. Here is the link:
http://www.palmpowerups.com/readarticle.php?article_id=5
Unfortunately, this software is not free.
Posted on Apr 09, 2008
TI-84 Silver Edition blank screen with cursor in top left hand corner blinking. Keys not responding
The command line is full. Use the left arrow key to clear the command line. Then erase all previous entries, or reset the RAM
Sep 07, 2014 | Texas Instruments TI-84 Plus Silver...
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
How to flip screen around
The 6th generation iPod nano doesn't have an accelerometer, but its screen can still be rotated. Here's how.
Begin by putting two fingers at corners of the screen. This can be opposite corners (one finger at the top right corner of the screen and another finger at the bottom left corner, or vice verse) or corners on the same side (top left and bottom left, for instance).
At the same time, twist your fingers in the same direction (clockwise or counter clockwise). The screen should rotate with your fingers. Remove your fingers from the screen when it's oriented the way you want.
If you like my solutions kindly rate it.
Thank you
May 20, 2011 | Apple iPod Nano 6th Generation MP3 Player
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Nintendo DS The Legend Of Zelda
First of all, this crest is VERY difficult to draw correctly
But have you ever tried to draw the hourglass instead?
Sep 26, 2008 | Nintendo The Legend of Zelda: Phantom...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
Screen insensitive and vibrate mode not working
Hi, I had this problem, and fixed it. That's the good news. The bad news is that it involved taking the unit to pieces, and thoroughly cleaning the edges of the screen, and the inside of the case where it sits. Something had got trapped, which was throwing the tap out at the right hand side.
Jul 29, 2007 | O2 Xda II mini
Palm TX Handheld Logo
992 people viewed this question
Top Palm Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
