Question about Grilling
Weber charcoal grill repair
The flanges that close the vents on my platinum one touch weber grill have bent, and no longer close the vents. I am trying to replace them, but I can't figure out how to remove the vent handle. An I shaped bracket on top of washer inside grill bowl. Vent handle inserted through bracket holes with a washer outside of grill bowl. No visible anchor on the handle. Can someone help me with this. Owner's manual no help.
  • tbowens Apr 06, 2008
    You could be right. Will give it a try (the next sound you hear is me banging my head), should have thought of that myself. I can't say for sure but it almost looks likes there is a trigger mechanism that pops up into the grill bowl off of the vent handle. Limited rotation and limited back and forth movement. I even came at it with a hammer and a crowbar and couldn't get it to move.
  • 32 Answers
I NEED MORE INFO, BUT I THINK THE HANDLE IS HELD BY TENSION FROM THE BRACKET. MOST LIKELY TARS AND AN ITEM WE CALL "VARNISH" IN THE RESTAURANT INDUSTRY{ COOKED, ACCUMULATED FATS] HAVE JAMMED THE AREAS THAT ARE TO MOVE FREELY. LOOOK TO SEE IF THIS MAY BE THE CASE. FOR MOST APPLICATIONS TRY USING WD-40[NO OPEN FLAMES!!!] TO DESOLVE ANY BUILD-UP.(ALLOW TIME FOR WD TO WORK, MAY TAKE MORE THAN ONE APPLICATION)
Posted on Apr 05, 2008
I realize this is an old post but as someone who was also recently frustrated with the same problem I thought I'd post anyways in order to help future Weber owners who may also be searching for a solution.
The vents can be bent back!
1. Remove the lower ash pan and aluminum shroud.
2. Using a blow torch heat the lower portion of the bent vent for 45-60 seconds.
3. Turn vent handle to the closed position.
4. Use a standard screwdriver to pry the vent up from the underside of the kettle while simultaneously using free hand to apply pressure to the outer (cool) end of the vent ear.
Problem solved!
Time to start the coals and add your meat of preference!!
Posted on Jul 29, 2012
  • Matthew Feb 23, 2019
    I accidentally bent the vent hole by uninstalling the old weber vent system. When installing the new system the wings cover the holes, however I cannot fit the bottom washer in place, under the bowl. I was able to get the slider rod in without the washer & it appears to be working. Is the bottom washer necessary?
SOURCE:
Vent settings for best heat smokey joe siver model
Not sure what you're asking, but if you want to know how to get the hottest fire, open all the vents. "Best heat" doesn't really tell us what you want. Best heat for what?
Jul 10, 2014 | Weber One Touch Silver Charcoal Grill
How do I get best results with the weber BBQ as far as heat efficiency
You can actually get some good cooking tips at the weber on-line site. That said, you really don't want to concentrate on efficiency but rather on the type of food you are cooking. I always used to stack the brickets in the beginning to get them lit and graying and then spread them for an even heat to enable cooking on all of the grill surface. If you need more concentrated heat from below then leave them stacked or in a bricket rack.
Jul 22, 2011 | Weber One Touch Silver Charcoal Grill
Do I need briquettes for my weber silver grill
No, you don't use briquettes with a charcoal grill. Charcoal is slow to heat up any way, adding lava rock (briquettes) would make it even slower and hard to keep lit. However, its OK to add cooking wood chunks after the charcoal has heated up, to add a smokey flavor.
Happy Grilling!!
May 24, 2011 | Weber One Touch Silver Charcoal Grill
How do i get the max heat out of a charcoal Weber, re cover and bottom vents. Should they both be fully open? Cheers.
open the bottom vent all the way. after the grill starts close the top vent then put the lid just slightly off to the side. the top will hold the heat in and the grill will reach the max temp.
Apr 20, 2011 | Weber One-Touch Gold 18.5 Grill
I just bought a 18.5 in. weber and after im done cooking and close the vents the coals continue to burn much longer then my 2 previous grills.
Sue, this question/problem has been voiced a couple of times before and I'm not sure it's a problem with the grill. It's more of a problem, of how much charcoal is being used and how long it takes to grill whatever you're grilling, how many portions are being grilled and how long it takes.
My experience has been, after during numerous grilling demonstrations and cooking shows, most folks use way to much charcoal for what they're trying to grill. Charcoal is slow to heat up completely and slow to cool off and extinguish. Especially, if you're using to much charcoal. The slogan I always use when cooking with charcoal is "less is more". When you use less, throw in a couple of chunks of Western Cooking Wood. It will add a great flavor and may convince you to switch to it entirely. Also, all natural lump charcoal lights faster and burns cleaner than charcoal briquettes. It also cools off faster, when the grill is closed completely.
Give it a try, I know you'll see a difference.
Apr 13, 2011 | Weber Grilling
Hi, the charcoal in my grill goes out after about 45 minutes
Somtimes using a charcoal grill can be tricky...are your charcoal briquetts fully lit and ashed over before yo start cooking...if so..the next trick is to get a good "draw" so the grill operates properly...you have to get air in the grill thru the botom vent and out te grill thru the lid vent at just the right rate to get a nice stream of smoke thru the lid vent without flaming up under the food.You have to make sure that you have the bottom vent partially opened to allow air to flow thru...remember air in thru the bottom and out thru the top....also try to use a good quality charcoal such as "Kingsford" because they burn longer than any I've ever used....It's a trial and error thing.....PS....don't try to relight by squirting starter fluid...This is very dangerous.... hope this was helpful..
Mar 20, 2011 | Weber One-Touch Gold 22.5 Grill
When cooking do you leave the lid holes open or closed
Oct 31, 2010 | Weber One-Touch Gold 18.5 Grill
Cooking a whole chicken / lamb roast
Good Evening, I love cooking with Charcoal/Wood. The bottom vents will adjust the temp, closed the coals burn slower and cooler. The top vents also control the temp, however more importantly the flavor by keeping the smoke in or out. With a roast you want low heat so I would close the bottom vents 1/2 way or so and since i like a smokey flavor of Hickory would keep the top vents closed. The key to a good Barbeque none the less is slow cooking. It also takes fine tuning, wind, breezes all effect how fast/hot the coals burn. Don't be afraid to add more coals as needed as well. Good Luck and have a great cookout. Thanks for using FixYa. Jeff
Apr 20, 2010 | Weber One-Touch Gold 18.5 Grill
I need directions for using a weber grill
Open the bottom vent, open the top vent. Start your charcoal in a chimney starter (my favorite way). Dump in the burning charcoal. Wipe down grill grate with canola or other high temp oil. Place grate on grill, cover, set top and bottom vents to desired temp. Cook food. Cleanup.
Jun 14, 2009 | Grilling
Grilling Logo
1,087 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
