Question about whirlpool catalyst 27" washer
I have a whirlpool catalyst 27" washer and it just started flashing a F3 code, can you please tell me what that means/
thanks
paschal
  • 8,617 Answers
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Posted on Apr 05, 2008
SOURCE:
What does f3 flashing mean?
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Jul 08, 2011 | Asko W6222 Top Load Washer
I have a gold catalyst gsx9885jq0. It has a code reading, F3. It won't do anything.
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it. Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=3020600
Nov 21, 2010 | Whirlpool GSX9885J Top Load Washer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
what is your model # i looked at the manual there is no F4 code they only go up to F3 if you post your email i will send you the service guide
May 20, 2008 | Whirlpool Washing Machines
Whirlpool gold catalyst washer error code FF
FF on the catalyst models means the following. Let me know if you need more info or would like a link to where you can obtain a service manual for your washer.
If the transducer signals a high or a low water level for more than 16
seconds the washer will shut off and FF will flash.
• Press the RINSE OPTIONS button and select DRAIN/SPIN to drain
washer.
• Check the water level transducer hose and wire connections.
• Also check the pressure dome hose to be sure they are properly
connected.
• Check the water level transducer, see TEST #7.
Mar 04, 2008 | Washing Machines
What does this cod mean?
Post you email i will email you the PDF of the service manual but the only code i see is a F which equals FAULT the the "code" is H which is a no water detected entering the machine or Pressure switch trip not detected
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
571 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
