Question about Dell Dimension 4600 PC Desktop
Thanks Hollye, Thanks for the advice: on top of everything else, the software you've indicated is free! Ain't life grand. I'll let you know how the uninstall/reinstall of Norton 360 goes, and if it causes my boot drive to suddenly show itself once again. I appreciate your help. John
    Sergeant:
  • 313 Answers
Glad I could help!
Posted on Apr 05, 2008
Where is nikon service center in dubai ?
Nikon products service collection centers: ABU DHABI Grand Stores, Khalidiya, Tel.: +971 2 6312100. Grand Stores, Abu Dhabi Mall, Tel.: +971 2 6451115 Grand Stores, Marina Mall, Tel.: +971 2 6817817 Grand Stores, Delma Mall, Tel.: +971 2 5503061 Grand Stores, Central Souq, Tel.: +971 2 6278617 DUBAI Grand Stores, Burjuman Centre, Tel.: +971 4 3523641. Grand Stores, Al Maktoum Street, Tel.: +971 4 2213700. Grand Stores, Mall of the Emirates, Tel.: + 971 4 3414555 Grand Stores, Ibn-Battuta Mall, Tel.: + 971 4 3685353 Grand Stores, Deira City Center, Tel.: + 971 4 2943071 Grand Stores, Mirdif City Center, Tel.: +971 4 2843055 Grand Stores, Dubai Marina Mall, Tel.: +971 4 4342540 Grand Stores, Dubai Festival City, Tel.: +971 4 2329391 Grand Stores, Dubai Mall SF, Tel.: +971 4 3398614 Grand Stores, Dubai Mall LG, Tel.: +971 4 3398915 Grand Stores, Image Arts Garhoud, Tel.: +971 4 2868010 Grand Stores, Dubai Outlet Mall, Tel.: +971 4 4264915 SHARJAH Grand Stores, Mega Mall,Tel.: +971 6 5746341. AL AIN Grand Stores, Al Ain Mall, Tel.: +971 3 7515551,
Oct 19, 2014 | Nikon Coolpix 5700 Digital Camera
Lost picture
Try unplugging everything and then plugging it back in. When my xbox had the "ring of fire" my brother asked me to fix it and I just unplugged and re plugged it worked and came back to life. (be careful that you either have the instuction menu for setup of you can remember where all the plugs go, otherwise you'll have to right down what goes where or else you may get confused and never be able to fix your poor television)
Mar 22, 2012 | Protron PLTV3250 32 in. LCD Television
I have a 2004 pontiac grand prix with white smoke coming from underneath the hood and tailpipe.
Sounds like you've got a coolant leak. Check the condition of your radiator cap (look for deteriorated rubber, etc). You'll probably also need to top your coolant system off as well. It would help you if you pop the hood before starting the car, start the car and then watch the engine compartment so you can identify where the white smoke is coming from so you'll know what needs repair. No need to be a master mechanic to open a hood and watch an engine for 10-15 minutes...
Also as a last resort if you're having overheating issues but need to drive in an emergency you can turn your heater on full-blast... the heater can act as a supplemental radiator (useful for when the engine fan fails), just turn it to max hot and max fan and roll the windows down as necessary. Turning off the AC and extra electrical accessories helps as well because it puts less strain on the engine accessories, which put additional strain on the motor as it tries to provide power to everything.
Nov 19, 2011 | 2004 Pontiac Grand Prix
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
I have a 1998 grand am and the ABS light came on, what does that mean?
There's a pretty good chance that one of your front wheel bearing/sensors is bad. The sensor is probably built into the wheel bearing assembly.
You'll need to have an OBD2 scan done, to get the error Code to get a better idea of the problem.
Some auto parts stores, such as AutoZone, will scan the codes for free.
If the code indicates a wheel sensor issue, you can try to unplug the sensor, clean the connection with contact cleaner, and reconnect. I've never been that lucky.
The bearing/snsor will cost a minimum of $100 plus labor.
Get the free scan first... Good Luck.
Jul 21, 2011 | Pontiac Grand Am Cars & Trucks
I have a 1995 Dodge Grand Caravan. The dashboard gauges just stopped working, no speedometer, no fuel gauge, no odometer, no Thermo (engine H-C)Gauge. Checked fuses, b ut don't believe speedometer...
Okay...I've answered this question about 100 times. And anyone that's listened to me has fixed their problem. I know it sounds unconventional...but trust me because you have nothing to lose at this point. Go out to the vehicle...turn the key on the run position...hit the dashboard above the steering wheel hard. Not hard enough to break it or you...but hard. A couple times if necessary. Everything should spring to life. What usually happens is the instrument cluster plug (contact) becomes corroded and loses contact. Either that or the solder joints have become compromised and lost contact. It'll mean that you'll have to replace the instrument cluster. Are the lights by the heater control flashing? I suggest this as a diagnostic application only. Try it and then get back to me. If it works, which it should...PLEASE leave a comment and rate my assistance. Had someone done it in the past, you would know that it works and fixed it already. You can check my comments from waaaaaaay back. One of the Fixya experts tried it and left a comment. It works (a day, week, month, year it depends). It's not a new vehicle and money in your pocket is found money. Thanks.
Jul 21, 2011 | 2003 Volvo S60
Can opera mini be used in tw1 duo myphone and get free internet access?
Thanks for visiting FixYa!
I've heard through the grapevine that it may be possible once or twice but you'll be cut off very quickly. Also, it's a crime to access the Internet in such a way. I'm going to caution you not to try it. It's good advice. I hope you take it.
Jun 27, 2011 | Cell Phones
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dell Dimension 4600 PC Desktop problem
Kaspersky - best rated this year - and has a small footprint on your computer. I personally use Avast 4 Home - it is a free application anti-virus for home users and it has done a great job on my computers (I have eight up and running all the time).
Apr 05, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
Alun Cox
