Question about Kenmore 74602 Gas Dryer
Kenmore gas dryer. 70 series
I was pulling out the filter to get excess lint and the lint fell back into the dryer and now the dryer will not start up. it makes a noise like it usually does to start but will not do anything
    President:
  • Kenmore Master
  • 2,651 Answers
Sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Posted on Apr 06, 2008
Kenmore 70 series dryer just hums when you push the start button and doesnt turn on. when you quit pushing the start button the machine is silent...
Posted on Jul 18, 2011
Foreign object fell in lint trap of Kenmore series
Try to use a vacuum hose
Or will have to open up
unplug
2 screws at top of sute where filter goes
take all screws of back
take screws off back of shute
put back in reverse
Sep 18, 2014 | Dryers
I HAVE A KENMORE 400 SERIES DRYER. THE LENT NO LONGER STICKS TO THE FILTER. WHEN I PULL THE FILTER OUT TO CLEAN IT, THE LENT SLIDES OFF THE FILTER CONTINUALLY CLOGGING THE VENT IN THE BACK OF THE DRYER....
Try cleaning the filter to remove any residue from dryer sheets (a dish detergent solution should cut the softener build-up). Be as gentle as possible. An old toothbrush is useful for this.
Also, a weak exhaust flow may be the culprit. Check the dryer vent line all the way outside for excess lint.
Your fan impeller (inside the dryer) may be loaded with lint, too.
Apr 29, 2010 | Kenmore 400 6943 Dryer
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
My Kenmore 70 series is heating up but NOT drying. I checked the vents. They are clear. The exhaust from the back of the dryer seems to be pretty weak.
Good day,
The lint filter is supposed to do the job, but........
1. Remove lint filter.
2. remove 2 screws under lint filter, then pry up both front ends of the front of the top lid.
Lift lid up and prop up but do not go completely vertical.
3. Remove back cover of the machine.
4. Remove all the screws holding the vent shute on the left side.
5. Lift this shute out and up as far as possible, watching out for the wires.
6. Inspect the blower wheel and it's housing with a light. Should be filled with a buidup of lint.
7. Clean out and reassemble.
Dec 05, 2009 | Kenmore 74602 Gas Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 74602 Gas Dryer Logo
202 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
