Question about Olympus FE-190 Digital Camera
FE-190 I cannot shut off my camera. It beeps and the lens will not move to shut down. The camera screen is black. When I try to zoom in or out it just beeps.
  • Midsy Umali Apr 13, 2008
    I pretty much have the same problem. It beeps, and images seem to be out of focus, even during near shots. When i try to turn it off, the lens won't go down like it used to.
  • xavier_30 May 24, 2008
    Same symptoms,
    Olympus asked about 150€ to repair it ! as the warranty was passed
    Problem Solver:
  • 5 Answers
If you take the battary out, your camera should re-set itself.
when you put it back in, make sure it's fully charged.
make sure you're photos are backed up first!
if they're saved on a card, take the card out before the battery, and re-insert it after the camers sorted itself out
Posted on May 27, 2008
I had the same problem. I just deleted all the images and now it works fine.
Posted on May 05, 2008
No, I didn't get any responses.
Posted on Apr 06, 2008
SOURCE:
Camera was dropped, now lens wont retract, no image on screen,when turned on a series of buzzes and beeps then the camera turns itsself off.
Bad news I'm afraid. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either of these conditions causes the camera to shut off to prevent further damage, and either condition will require professional repair.
Oct 19, 2009 | Olympus FE-360 Digital Camera
Olympus Fe-330 The lens will not open, Please help?!?
Lens is stuck!... Possible some dust won't let the zoom to move.
Hold upsite down the lens and very softly tapped around.but do not force the lens. then try to turn on in same condition. If did not worked
try to oposite , Show lens optic to up to sky and try again.
If did not moved you need techguy to remove and clean the lens base from dust and lubricated again.
jmc
Aug 16, 2009 | Olympus FE-330 Digital Camera
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
Blank view finder fe-190
try switching your camera on in a dark room (do it at night with the curtains closed and the lights off).
if the screen lights up (should still be black or a very dark green),
then the lens or light sensors might not be functioning correctly.
if the screen stays conpletely black, then the actual screen might be damaged.
note- you might need to let your eyes adjust to the darkness before you switch your camera on.
May 22, 2008 | Olympus FE-190 Digital Camera
My camera isnt working
if the picture turns all white, then you might have a problem with the screen.
-or your're just aiming it at a bright object. (try covering the lens with your hand- dont actually touch it, just block out the light and if the screen goes dark then its still working)
if some sand or grit got inside your camera, then you have a serious problem, as sand is very abrasive,and could damage the internal mechnisims.
you should seek professional help on getting the inside cleaned out.
May 03, 2008 | Olympus FE-190 Digital Camera
Camera is stuck on minimum zoom
Try to replace batteris and look as well for batteries right placement. Good luck!
Jul 15, 2007 | Olympus FE-140 Digital Camera
Olympus FE-190 Digital Camera Logo
118 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
