Question about Refrigerators
I have a Crosley CT17A2, 16.8 cufu fridge with top freezer. I do not have any water hooked to the fridge. However, quite frequently water runs from the top back surface of the fridge and pools up under one of the produce storage bins, and often runs onto the floor. Suggestions? Thanks, Casey
  • 32 Answers
Therer should be a tube leading from the interior drain hole into a catch basin under the unit where it is evaporated using heat generated y the condenser unit. check to see if it has dislodged.
Posted on Apr 05, 2008
The fridge is dripping water from the top ceiling in the fridge and the fridge itself is making a terrible noise. We unplugged the fridge for four hours and now it is quite however there is ice covering...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
My top freezer Whirlpool refrigerator (ice maker not hooked up) is getting water on top shelf and icing up. Also, water in crisper drawers.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Whirlpool Refrigerators
The icemaker quit woking but the freezer is cold, and the fridge is not cold.
heatman101
Sep 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Leaks water inside fridge when door is opened. Also leaks water under fridge when closed for long periods of time.
if this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Sep 01, 2010 | Crosley Refrigerators
Water leak
First check the seal is sealing tight. To do this use a piece of paper and close the door it should have resistance when pulling the paper out. If all is good your drain is clogged up. To clean this remove the back panel at the bottom you will see a hole about a 1/2' in diameter clean this out with warm water and a turkey baster or a piece of wire if necessary. Be careful not to puncture the tube. The drain tube runs all the way to the bottom to a drain pan. After it is clear run a baking soda water mix 50-50 down the drain to prevent future clogs. Here is a link to accesssing the drain.
http://appliancehelponline.com/refertopevapfan.html
Jun 03, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge comes on frequently.
The best thing to do is pull it away from the wall. Get the back bottom cover off (probably, card board). Get a good vacuum and clean the condenser coil of any dust....Getting the condenser coil as clean as possible, then replacing the fan motor would be your best option to get the fridge to run quieter and less frequent.
May 03, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Crosley side by side. freezer/refrigerator. Has ice maker/water. Question is why is the fridge side freezing things. Its on lowest setting? I tried cleaning out the coils that were under the fridge.
there is a damper control on the top left of the fridge compartment that may be stuck in the open positin open the fridge door and turn off the unit completely you should be able to here the damper door close. if you do not it may need to be replaced,and or your thermostat for the fridge needs to be replaced.
Feb 23, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
