Question about HP Compaq Presario C500t Notebook
How to tell if the battery needs to be changed
I have the notebook charging but it wont come on
  • Thrice Apr 06, 2008
    My charger had broken, and i attempted to splice the wires back. A spark occured on power up and shorted something, could it be the battery? the motherboard doesn't seem to be burnt or anything obvious... i haven't ran a meter on it yet though...
    Sergeant:
    Champion:
  • 293 Answers
Maybe you have a charger problem, check if the light on charger lights up,if the lights on , probably the problem is on the battery
Posted on Apr 12, 2008
Acer aspire 5735 takes a charge but wont power on
Check memory sticks (one at a time in different slots)
and
Remove battery, and power cable. Keep power button pressed for 5 min then insert only power cable and try to turn on
Mar 21, 2013 | Acer Aspire 5735 Notebook
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
My inspiron 1545 wont turn on battery and charger are fine can anyone tell what could be wrong
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 23, 2012 | Dell Inspiron 1545 Notebook
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
How to increase notebook battary backup
Hi, the problem is you cant without buying a new battery but what they dont tell you and should tell you is this.
when your using your notebook off the mains you should remove the battery as this keeps it working at its best only use the battery when you need to and after give it a full charge then leave it out whilst you use the notebook on the mains.
leaving the battery in will sap the life out of the battery and you will end up needing a new battery every few months as it just wont hold the charge as it did when new.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 21, 2010 | Acer Aspire 5100-5033 Notebook
Bought a new battery and it wont charge, says on AC power
Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
Jul 22, 2009 | HP Compaq Presario V2000 Notebook
BATTERY CHARGE
you need to change your battery. Most likely the circuit in the battery is no longer functioning properly
Apr 07, 2008 | Acer Aspire 3610 Notebook
I have a balance laptop model 557s
ok..pull the battery first, and try it with only the power cord..
the battery MAY need to go through a charge/discharge/recharge cycle..
this will tell us.
Feb 28, 2008 | Balance CN6555 Notebook
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
