It was shuting itself off and on and then I got a 7 inch wide black strip from top to bottom it is a samsung plasma model #hps5053x
  • sstapel Apr 05, 2008
    What details do you want, it is a samsung plasma 50 inch model # hps5053x. It was shuting itself off and on and then I got a black stripe about 8 inches wide from the top to the bottom.
    The Tv set is onley a little over a year old is this common and what about the black stripe from top to bottom
    Genius:
  • 3,422 Answers
Can you please give more details about your problem.
Waiting for your reply..
Posted on Apr 05, 2008
  • 2 more comments
  • Priya darshan Apr 05, 2008
    OK,
    FEW TROUBLESHOOTING STEPS YOU CAN TRY:
    ONE: Check the line cord. Wiggle both ends near the molded part.
    TWO:Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
    THREE:The whacking test is to just bang or smack the set with your hand
    on the back, side, top, etc., to see if there are loose connections or
    cold solder joints inside that are acting up. If so, the banging should
    knock them back to normal and the set should restore. You might have
    to use some creative banging and some have had to put a book or
    magazine under one corner to torque the chassis enough to get it to
    work reliably.
    If the problem still persists then like i said before,you will have to get it repaired by a technician.
    Goodluck,
    Please don't forget to rate the solution
    The TV is shuting itself off and on because the power supply is bad or the convergence circuit is bad.
    they are the most common to do this.the problem here is the age of the
    tv. a repair cost would range around $300-$400 this is a lot to put into
    a old set.
    You can try my troubleshooting steps first to see if that helps you.
    If it is new under warranty then please go for or repair or just replace it.This is the only solution to fix your problem.
    I don't need any details now.I have given the solution to your problem please go through it.
    As i said before Tv shuting off and on automatically is a common problem.This happens when the power supply is bad or when the convergence circuit is bad.
    Regarding the black stripe problem from top to bottom you can try resetting all of the cables and connectors. This is a
    communication problem between the processing board and the display or
    the display is bad. Lets hope for the bad connection.
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
HITACHI CMPAD14D 42 in plasma it has a black strip some 3 inches wide runing near the middle of the tv from top to bottom and it some time comes on then dissapears and so on and so forth
hITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
Oct 02, 2008 | Televison & Video
Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Jul 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Line in center of screen
if the line is about one inch wide you may have a chance that the address board has failed, if it is only 1 pixel wide then there is a really good possibility that the plasma panel itself if bad, this set had a 2 year warranty from samsung, you might want to give them a call,,they are very customer satisfaction oriented
Nov 28, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
