Does my Aspire 5580/5570/3680/557OZ laptop support an wireless internet card? Or do I have to use a wireless router?
    Genius:
  • 1,027 Answers
It does support a internal wireless mini pci card, however access is probably under the keyboard.
to see if 1 is installed, goto start, right click on my computer, left click on properties.
In Vista select device manager from left column,
XP left click on hardware, device manager.
click on the + by network adapters and see if it is listed
wirelesse.g. intel pro,atheros, broadcom, etc.
to turn it on is usually a slide switch in front next to external head phones and bluetooth.
Posted on Apr 05, 2008
SOURCE:
My acer aspire wont connect to my centurylink wifi
Try re-installing the wireless card driver and the configure the wireless card to the wireless router's wireless settings. You can also have a look at the wireless card settings in the computers that is connecting to the wireless router/Internet and then apply these settings to the wireless card in the Acer.
Nov 08, 2012 | Acer Aspire 5253-bz692
Sylvania7'netbook
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Aug 12, 2012 | Acer Aspire One AOD150-1920 Netbook
Why will my Acer Aspire 5552 running W7 only connect to the internet when it's near the router? When elsewhere in the house, it shows 2 bars on the signal strength, but will not connect to the rou
That means you have a crummy internal wireless card. Your best bet would be to purchase a USB wireless card and your problem will be solved.
Mar 21, 2012 | Computers & Internet
I HAVE A ROUTER CONNECTED TO ANOTHER PC COMPTER AND I WANT TO CONNECT TO THE INTERNET WIRELESS ON MY ACER DESKYOP COMPUTER
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 03, 2011 | Acer Aspire L310 (ASL310UD631A) PC...
Setting up wireless connection.
Jun 09, 2011 | Acer Aspire 5610-4648 Notebook
I do not know how to connect to internet thru wi-fi with my aspire 4738Z
Apr 21, 2011 | Acer Aspire 4730-4947 Notebook
Can't connect to the internet through wireless on my daughter's acer laptop
Your daughter's wireless card in her laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 27, 2010 | Acer Aspire One PC Notebook
Acer aspire one 8.9 wireless wont work
First make sure the wireless card driver in the computer is installed and the wireless is enabled and working.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 29, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Wireless connection is detected, but will not connect
If your other laptop is working fine, then have a look at the configuration of the wireless card and use the same configuration on the one that is not working.
Depending upon your wireless card make there is a program that enable you to setup the wireless card. Go to Start - Programs to locate this program. If your wireless card is built-in refer to your Acer manual.
Encryption is setup on the wireless router and these settings are also used to configure the wireless card. If the encryption is already setup, changing the encryption will affect your other wireless card, therefore all the wireless cards will need to be reconfigured with the new encryption to work with the wireless router.
May 09, 2009 | Acer Aspire One PC Notebook
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Open Questions:
Epson Printer technical support 1=855=536=5666*$+ Epson Printer Customer Helpline DFUXJQN [email protected] is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected] email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected] support number When you are using the [email protected] for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected] support number and ask for the help. Once you dial the [email protected] customer support number, you come in contact with a team of experts at the [email protected] customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected] support phone number will help you with that simply and quickly. This is [email protected]'s best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected] agent. Features of [email protected] support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected] customer support phone number. Here are some of the features of customer service: The [email protected] customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected] customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected] provides you the facility of [email protected] support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected] Here are some of the issues that you are going to face when you are using the application:
Oct 22, 2019 | Epson Computers & Internet
AOL MAil TecH SuPPoRt {1=855={536}{5666}#[email protected] CONNECTICUT This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
Epson Printer technical support +{1~855*536~5666*} Epson Printer Technical Support XOQWIUA [email protected] is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected] email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected] support number When you are using the [email protected] for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected] support number and ask for the help. Once you dial the [email protected] customer support number, you come in contact with a team of experts at the [email protected] customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected] support phone number will help you with that simply and quickly. This is [email protected]'s best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected] agent. Features of [email protected] support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected] customer support phone number. Here are some of the features of customer service: The [email protected] customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected] customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected] provides you the facility of [email protected] support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected] Here are some of the issues that you are going to face when you are using the application:
Computers & Internet Logo
137 people viewed this question
Ekse
Marvin
Marvin
