Question about IBM ThinkPad T21 Notebook
IBM Thinkpad T21 LCD problem
Hi, I have an old IBM Thinkpad T21 and think I need new LCD. The light on the computer doesn't come through unless I open and shut cover a few times.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
My T21 screen flickers sometimes. Yesterday I complete disassembled the computer and found that the monitor cable looked fine. What else could be causing the occassional flickering?
Posted on Jul 30, 2008
I had the same problem with my T21. I also had to close and open the lid a few times in the beginning, but after a while even that didn't help anymore.
So, I took the whole thing apart, and what I expected turned out to be right: the ribboncable going to the display was cracked where it leaves the lid and goes into the pc-case.
It is possible to repair it (I know, because I did) but if you're not used to work with a soldering iron (and your eyes are in perfect shape), don't even try. These contacts are so tiny that I had to work through a magnifiying glass all the time.
First, you have to remove the outer shell of the ribboncable. The easiest way to do that is with one of these highspeed rotary tools. (Note that this shell is made of conductive material, watch out with the debris)
When the cover is removed, you can see which traces are broken. Before you can solder the broken ones, you have to remove the varnish from them. That can be done with a sharp knive. Be very careful, because the copper layer underneath is very thin.
In my case, four of these traces at the side of the cable were broken (varying in size between 1/2 and 1.5 millimeter).
I soldered some copper wires over the fractures, and that did the trick.
It works again!
Biggest challenge now is to get it assembled again :-)
Succes,
JVdB.
Posted on Jun 06, 2008
  • 3 Answers
I had the exact same problem, and opening and closing the lid helped for the first little bit. The problem degenerated to the point where I was poking the cable leading to the inverter board (the brains of the monitor). The cables are rugged enough to stand some wear and tear, and so the problem may lie within the inverter board for the LCD. A new one can be found on e-bay for less than $15 (shipping included). I know spending money sucks, but the inverter board has been known to be an pain in the neck for a lot of people with ThinkPads. Hope this helps!
Posted on May 27, 2008
    Sergeant:
  • 202 Answers
Hello shadl
Am I understanding your correctly? - the monitor of your T21 is working intermittently? Please, let me know if I've misunderstood your description of the problem.
If the issue is w/ the monitor, ....
And the symptoms are intermittent and change w/ opening and closing the cover (monitor) then there's a good possibility the problem isn't w/ the monitor itself rather it's w/ the cables or wiring going from the monitor to the mainboard. If that is the case, whether it is repairable w/o replacing the monitor will depend upon the cables and/or wiring involved.
It would make sense that an issue like that was caused by worn or damaged cables/wiring as those are the parts of the monitor that would've been subject to wear and tear over time.
I recommend you disassemble the monitor from the laptop and carefully inspect all the cables and wiring that run between the monitor and the laptop.
I will see if I can find a service manual online for you that will step you through removing the monitor.
If it does turn out that the problem is w/ the monitor itself or that the monitor's wiring or cables cannot be repaired, you can search the Internet for another Thinkpad T21 that you can salvage parts off of. (eBay would be one good place to look.) You can try finding just the monitor but I think you'll stand a better chance at finding a T21 that is being sold for salvage.
In the interim, you should be able to connect an external monitor and use the computer w/ it for now.
IF you connect an external monitor and the symptoms persist, then the problem isn't w/ your monitor at all. Be sure to post back here and let us know if that is the case, too.
Please, let me know if this response was "Helpful" or a "FixYa" for you or, of course, if you have additional questions, etc on this topic.
If I did not answer your question satisfactorially, plz, b4 assigning a "Thanks for Trying" or lower rating to my "Solution", let me know. I may have misunderstood you or the problem you are experiencing. In any case, I will work w/ you until your problem is resolved or diagnosed. I promise! :)
Thank you
BJ
Posted on Apr 05, 2008
  • Anonymous Apr 05, 2008
    IBM THINKPAD T20,T21, T22, T23 Series MAINTENANCE MANUAL can be found HERE.
    (01) In the Bookmarks on the left, click on: THINKPAD T20, T21, T22 AND T23 SERIES
    (02) Then click on: REMOVING AND REPLACING A FRU (field replaceable unit)
    (03) Next, click on: 2040 LCD PANEL
    (04) In the right pane, click on: 2010 LCD ASSEMBLY ON PAGE 119
    (05) Now, in the right pane, scroll down the pages to see the illustrations and instructions for removing the LCD panel.
    There is also a parts list in this manual that includes the LCD panel.
SOURCE:
I cannot get network connection with my ibm t21 thinkpad .have a wireless router abd my hp laptop is working fi
hi
the T21 has PCMCIA slot , you need a WiFi card (PCMCIA) : i dont believe it has built in or isntalled WiFi card.
Feb 05, 2012 | IBM ThinkPad T21 Notebook
Ibm thinkpad t21 only have 16 bit color and 800 x 600 pixels. looks like its in safe mode but its not.
Check video drivers. Download new one, uninstall old drivers, restart computer, install new drivers, restart computer.
Then right click on desktop -> propertites -> display.
Aug 08, 2009 | IBM ThinkPad T21 2648 Notebook
How to remove the display on IBM T21 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Feb 03, 2009 | IBM ThinkPad T21 Notebook
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: [email protected] (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Replacing the lithium backup battery in IBM T21
You'll need to remove the keyboard. Two screws on the bottom hold it. Then take a small flathead screwdriver and pull up one side, it will then lift up & out. You should be able to see the C-MOS battery connector.
Jun 10, 2008 | IBM ThinkPad T21 2648 Notebook
IBM ThinkPad T21 / Network
To my knowledge an IBM ThinkPad T21 originally was shipped out from the manufacturer without a WiFi networking interface, sorry.
Kind regards.
Feb 08, 2008 | IBM ThinkPad T21 Notebook
Cracked TFT screen on IBM Thinkpad T21
HERE IS A LIST OF P/N THAT WILL WORK
46L4843 LCD 14.1
05K9942 LCD XGA 14.1
05K9678
05K9668
05K9567
05K9944 ALL SUB TO 04L2348
Oct 16, 2007 | IBM ThinkPad T21 2648 Notebook
IBM ThinkPad T21 Notebook Logo
461 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
