Question about HP Officejet 7210 All-In-One InkJet Printer
HP 7210 OfficeJet - unnecesary cartridge messages
I replaced my print cartridges and now each time I print (any type of document) 3 boxes appear, one after the other. The first says "Photo Color", the second "Tri Print", and the third "Black Print".
None of them are necessary.
Please advise on how to rectify.
We had the same problem - after 2 1/2 years suddenly the dreaded dialog boxes appeared out of nowhere! We had tech support on the phone for at least 30 minutes to no avail. Finally we uninstalled and reinstalled the printer and all software and it disappeared.
Good Luck!
Posted on Apr 26, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
HP officejet 7210 error message color ink refill
this error is recomded for the printer becouse printer will count the print out
Apr 12, 2010 | HP Officejet 7210 All-In-One InkJet...
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Recurring "cartridge successfully installed" message
Download the Kyocera Driver Deleter tool from here:
http://drivers.softpedia.com/progDownload/Kyocera-KM-Deleter-281031-Download-18304.html
Run the tool and delete the driver for your HP. Disconnect the printer, then use Add/Remove programs to uninstall the HP software.
Reboot.
Reinstall the HP software and reconnect the printer when prompted by the software install.
After this I didn't get the message again.
Hope this helps!
Mar 18, 2009 | HP Officejet 7210 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
