SOURCE: HP screen - USB ports on screen not working
Did they ever work or is it new? You need to connect the USB hub to a USB port on the computer.
Take a look at this, figure 13 shows how it is to be connected:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065974&tmp_track_link=ot_recdoc/c01097300/en_de/c01065974/loc:1&lc=en&dlc=en&cc=de&product=3440923
click that link or copy and paste it into your browser.
EJ
SOURCE: remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
SOURCE: Monitor to PC Cable to get Monitor USB Ports Working
Belkin F3U133-10 Hi-Speed USB 2.0 Cable (10 Feet)
http://www.amazon.com/Belkin-Pro-Device-Cable-Feet/dp/B00004Z5M1
USB 2.0 A Male to B Male 28/24AWG Cable - 6FT
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10303&cs_id=1030301&p_id=209&seq=1&format=2
SOURCE: We had a black and now the monitor won't turn
It may have blown fuse, it should be located close to where the AC power goes into the monitor, look for part with Fxxx labelling.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
