Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
Printer/scanner problems i have a printer/scanner combo. printer works great, but i can't get the scanner to function. its really important that i get it working soon. any help would be much appreciated.
    Genius:
  • 2,785 Answers
Did you try to reinstall the driver if the problem persist than you send it for servicing
Posted on Apr 22, 2008
When I try to scan my computer does not see the scanner but I have no roblem rinting
This is a common problem with all-in-one printer/scanner combos. Printer drivers and Scanner drivers are installed seperately unless the driver cd is REALLY high-speed (i've never seen it work once). What you'll need to do is open your control panel, go to "scanners and cameras" and click "add an imaging device" (on the left side of the window). It'll start a wizard to walk you through the steps of installing the scanner. Make sure the scanner is connected and turned on, and that you have your driver cd/installation disc loaded. If you dont have the disc, then you'll need to have the drivers in a folder somewhere on your pc, and you'll have to manually point the wizard to that folder. This should square you away. Good Luck
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I am trying to Scan to PC, but the printer does not show my PC on the options, however, I can see other PCs
do it the other way around...make the command from the pc...using the "scanner and camera" feature from the all programs /accessories ..import from device ...
or ..if you have the scanners software into the pc ..run it to scan the document ..and save the job from the scanner's directory ..
if your pc it is not seen ..verify if the printer/scanner's driver it is still installed into the pc ....
or..another way to do it ..is to use a photo manager ...into the computer ...that have a import from device action /feature ...and this will allow you to import any job from the scanner..by choosing the twain function and the name of the printer..
Mar 12, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Scanning
As with most scanners, place the document in the scanner for scanning. Open the software that you wish to use. Select "File" from the menu and then "Import". Your scanner interface listing should appear. Click on the device to begin your import from your scanner. Your scanner should scan the document and it will appear in your application. Be advised, Scanners scan in a Graphic format. To edit in a wordprocessor you will need some kind of OCR (Optical Character Recognition) Software to convert the graphics into a wordable form for editing.
Jun 11, 2009 | Canon Pixma MP480 All-In-One InkJet...
Scanner error on PC says "cannot properly communicate with scanner. Make sure the scanner is on, properly connected and properly set up to scan." the test scan works and i can see the image. the printer...
Try and open MS Word and import a picture into a document via scan, follow the prompts in Word and it should work fine. If you don,t have MS Word you can download a completely compatible application at Open Office.org. It also has the same functionality is free and allows you to save documents as .doc, .xls, etc. Sometimes a scanner requires additional software or drivers in addition to functioning as a printer. I have found scanning internal to an application a workaround or test for the scanner. If this works I would review the installation or contact the manufacturer or website. Or post and we can give it another try.
Jun 04, 2009 | Epson Stylus CX5800F All-In-One InkJet...
HP Scanjet 5470c
Try carefully taking the scanner apart and cleaning it out. A buildup of dust, even a thin layer can greatly reduce the quality of your scans.
May 06, 2009 | HP Scanjet 5400c Flatbed Scanner
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Scanner
Please help me figure out why my Hp PCS 1410v won't scan
Jul 02, 2008 | HP PSC 1410v All-in-One Printer
Canon Pixma MP 470 Not Scannin
I have the printer. You need to scan through your image software on your desktop. The button on the scanner does not function.
With your image software, there should be an "Import from Camera" and "Import from Scanner." Pick the latter, and it will prompt you through the process.
Took quite awhile to figure that out.
Toby
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Lexmark p6350 vista drivers
Experienced the same problem.
The Dutch importer suggested to try photogallery, but was not sure of it. Howevr it proved to be the solution.
Open <windows photogallery>, then <files>, click on <import from camera and scvanner>, then click on <import>.
If your printer is switched <on> it now will start scanning and send the result in your file <pictures>, normally on your C:disc.
I just tried it and it functions well, at least in black-and-white.
Still have to check the color scanning, but that will probably no problem either.
Hope to have helped you, yours GerritDelden.
Jan 28, 2008 | Lexmark P6350 All-In-One InkJet Printer
HP PSC 1200 won't scan with VISTA
Use windows photo gallery....file/import photo from scanner or camera
Nov 14, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
