The cd is saying there is no CD but there is one in there and it wont eject.it makes a sound when you try and eject it
  • 667 Answers
Chances are the cd isn't properly seated. There should be a tiny hole in the front panel of the cd/cvd. Push the end of a paper clip or what ever you have handy into the hole. This is an emergency eject for the cd/dvd. Then check to make sure the cd was properly seated and retry. If this fixed your problem please rate fix. If not and you need more help please add a comment and I'll be glad to assist you more. Thanks.
Posted on Apr 06, 2008
SOURCE:
Can't get my cd to eject from car stereo
Did somebody put coins or something inside it? Try putting a high power vacume up to it and seal the whole opening with the vacume end...
Jun 18, 2012 | 2006 Chevrolet Malibu
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
CD Wont eject
Tried in Safe Mode Windows? Worst case is the shut it down, straighten a small paper clip, push it into the small hole on the surface of the DVD-ROM cover (It's a standard to have one). It should eject!
If system will not eject the CD due to a software locked it down, please list softwares the XPS have installed.
May 23, 2009 | Dell XPS One All-in-One TV Desktop with...
Radio wiring hook up
SOUNDS LIKE THE EJECT BUTTON IS STUCK ON, TRY TAPPING ON THE EJECT BUTTON OR RECHECK THE WIRING TO MAKE SURE THAT YOU HAVE ALL THE WIRES IN THE CORRECT SPOTS. ALSO CHECK TO SEE THAT THE GROUND WIRE ON THE BACK IS CONNECTED AS WELL. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
May 02, 2009 | 1989 Honda Civic
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
CD WONT PLAY
It sounds like it is attempting to read the t.o.c. (table of contents) which tell the unit where everything is on the cd,and failing to do so, then ejecting, the first thing to do is try cleaning the lens and if there is no change then replace the laser pickup
Nov 21, 2007 | Car Audio & Video
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Cd wont eject.
I was having the same issue with my KD-S5050. I also tried the CD eject lock reset with no results. By using the following steps I was able to reset my CD player and it is working properly again. On page two of the user manual is shows how to do a full reset of the cd receiver. While holding SEL (Select), press ATT (Standby/On Attenuator) for more than 2 seconds. This will reset the built-in microcomputer. http://www.fixya.com/Brands/J/JVC/Manuals/kd_s5050_cd_d2ce2654fa2aab37f3ad2b4ce1e33443/images/KD_S5050_CD_D2CE2654FA2AAB37F3AD2B4CE1E33443_2_p2.jpg NOTES: ? Your preset adjustments ? such as preset channels or sound adjustments ? will also be erased. ? If a CD is in the unit, it will eject when you reset the unit. Be careful not to drop the CD.
Oct 31, 2006 | JVC KD-S5050 CD Player
Open Questions:
SBCglobal MAil help {1^/855~/536~/5666-} desk NuMbER WASHINGTON Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
Oct 15, 2019 | VIA Computers & Internet
SBCglobal MAil CuStOMeR NuMbER {1=855={536}{5666}#[email protected] ALASKA Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
SBCglobal MAil CuStOMeR +1 855^536^5666}#[email protected] TENNESSEE Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
Computers & Internet Logo
50 people viewed this question
Ekse
Alun Cox
