Question about Panasonic DVD-RV32 DVD Player
Error message H07
When we tried to watch a DVD the other night, we got an error message H07. It had worked fine the night before. We borrowed it from our son and he can't find the instruction manual to find out what the error message is, can you help us?
  • 4 more comments
  • drew770 Jul 07, 2008
    When turned on my machine displays only a HO-7 error. WIll not do anything else. This has been a great player up til now... Thanks
  • hwguy Jul 19, 2008
    Giving the disk a spin avoids the H07 code, but by the time it gets to the dvd main menu the disk stops spinning. Is there a replacement spindle motor available, or is it possibly the drive circuit as well/instead?
  • Anonymous Jul 31, 2008
    KEEP GETTING H07 CODE. NOTHING IS WORKING
  • daniellenicc Aug 02, 2008
    how do we fix a HO7 code
  • Anonymous Aug 03, 2008
    we have the same problem HO7, does any one know of the solution???
  • stephzec Aug 11, 2008
    same thing with me. It was fine s few nights ago, now it says HO7 and wont play?
  • 82 Answers
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Posted on Apr 06, 2008
SOURCE:
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
Dvd player not working
the dvd i have it blows the fuse what could be the problem?
Feb 03, 2009 | Panasonic DVD-RV32 DVD Player
Error message or something
it means that your unit needs to be serviced and cleaned
May 07, 2008 | Panasonic SC-DK20 System
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Error Message H07 - what is it?
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Jun 09, 2006 | Panasonic DVD-CV52 DVD Player
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Panasonic DVD-RV32 DVD Player Logo
198 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
