Question about Harman Kardon AVR 130 Receiver
Voltage Spike / Power Surge Harman Kardon AVR 130
Hi, I have a Harmon Kardon AVR 130 that has been disabled by a voltage spike / power surge. The receiver will (obviously) not turn on at all. I popped the cover off, and checked the fuses-- none of them seemed to be blown.
My questions-- Where exactly does the problem lie? Is this something I can fix myself? If not, what would an approximate cost be to get this fixed at an audio repair shop?
Thanks in advance for your help!
  • Sandi McCoy Nov 25, 2008
    I had the same problem... took it to a tech and they wanted to charge me $280-$900 to repair it. They told me the "microprocessor" needed to be replaced before they could test the unit. any help?
    Problem Solver:
  • 16 Answers
In this case is pretty hard to give a diagnostic. There are plenty of possibilities. It has to be seen by a tech
Posted on May 24, 2008
SOURCE:
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
What's the difference between a surge and a spike in voltage?
A spike is an increase in voltage for 1-2 nanoseconds.
A surge is the increase lasts 3+ nanoseconds.
Feb 05, 2014 | Electronics - Others
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Can anyone advise what might be wrong with my Acer Aspire L100. We had a power cut the other night and it knocked off her computer. The unit will not restart and is completely dead. Are there any simple...
I am assuming you weren't plugged into a surge protector when you lost power. During power outages, spikes in voltage occur, so what happens is there's no mechanism to interrupt that spike by grounding, which surge protectors are designed to do. Any laptop/computer components cannot handle this voltage spike as they are delicate to certain voltage tolerances. I hate to say it, but your laptop is toast.
Jul 28, 2017 | Acer Aspire L100 PC Desktop
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
Damage to equipment from power surge
yes a spike may destroyed the mov (metal oxide variastor) inside projector replace it problem will be solved spike comes in the case of storm and lightning strike apc ups are well protected from spike and surge
Mar 04, 2010 | APC Back-UPS XS900 (BX900) UPS System
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 130 Receiver Logo
630 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
