Question about Sony Net MD Walkman MZ-N710
Problem transferring recorded files to my computer
When trying to transfer a recorded interview from the walkman to my computer through sonicstage 4.3.01.14050 I have this error report:
"Unable to transfer the tracks to My Library because they are recorded by Net MD or another computer".
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 10 Answers
SOURCE: Problem with transfering!
This is not a solution, but an explanation.
There is nothing wrong with your Net MD. This is a standard feature Sony included to protect copyrights. An extensive search of available soft produced only one non-commercial product which promisses such transfer http://winnmd.net/
No idea if it works, it's a shareware.
Posted on Sep 02, 2009
Anonymous
SOURCE: Unable to take audio files off Mini Disc player to PC...
Unable to transfer the following tracks to My Library because they are recorded
by Net MD or another computer.
Posted on Mar 27, 2010
I want to add video songs via sonic stage but they are not added..
The NWZ-S616F Walkman Player is not transferring the music using the SonicStage Software. Sony old Walkman player was using the SonicStage Software for transferring the files. You can use Windows Media Player 11 or higher, Media Manager for Walkman, Content Transfer Software or Windows Explorer for transferring the files to the Player.
Click here and select the operating System to download the Software for transferring the files.
Thanks for using FixYa.
May 06, 2011 | Sony Walkman NWZ-S616F MP3 Player
I need md pc suite
The Software used to transfer the songs to the Net MD Walkman is OpenMG Jukebox Software.
Before installing the Software, click here to download the Device Driver for connecting to the Computer.
Once the Device Driver is installed, download and install the SonicStage CP Software by clicking here.
After installing the SonicStage CP Software, install the SonicStage Security update.
These Software will help you in transferring the songs from the Computer to the NetMD Walkman Player and vice versa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Net MD Walkman MZ-N707 Recorder
My mp3 can be connected to mu pc and play all the music that it's stored there. but when I want to listen using my earphones there is nothing coming out (songs). I just fully charged... what could be the...
1. Check whether the file format of the audio file you are trying to play in the Walkman is supported by the Walkman.
You can check the supported file formats in the manual of the Walkman under "Specifications".
2. Check whether the issue occurs with all the audio files. If you are not able to play the file which you were able to play in past, then it must be the issue with the Walkman.
Then you may reset the Walkman to check whether the issue is resolved.
Press the RESET button located at the bottom of the Walkman to reset it.
You may also try Formatting (USE FORMAT OPTION IN WALKMAN) the Walkman and re-transfer the audio files to the Walkman to check whether the issue is resolved.
NOTE: Never format the Walkman in the Computer as it will delete all the Supporting files in the memory of the Walkman.
You may also try transferring the audio files using the supplied Software like Content Transfer, WMP 11 and SonicStage.
Jul 21, 2010 | Sony Audio Players & Recorders
Jun 30, 2009 | Sony Net MD Walkman MZ-N710
How to create my own library?
You will need to download and install sonicstage as this is the only program that can convert your MP3's to the sony walkman format. Once this has been installed, click file, import, scan folder, settings then choose the folder where you music is stored (i.e. my documents, my music) click ok and you music should be imported into you sonicstage library. Once your files are in sonicstage you can use the red arrow buttons to transfer the music you want onto your connected sony walkman
Jan 13, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Transferring files back to my PC from my Sony NW-HD5
first off when you transfered them using the sonicstage software it put what are called digital media rights that locked that file to the pc that loaded it, dont worrie there is a way... open up the mp3 player in one window and find the music you want drag it over to your desktop, then get a program called tunebite and that should help
Sep 27, 2008 | Sony Network Walkman NW-HD3 MP3 Player
How do i format my sony mp3player walkman
You have to work from Sonicstage.
Follow these steps:
Install Sonicstage (probably you've already done that)
After installing, connect the player to your computer and select 'format' from the menu (This will remove all data from the player, so you might want to make a backup).
Now transfer your music files to the player using sonicstage.
If you don't transfer them using sonicstage, the player data will get corrupt and tell you there is no data.
May 17, 2008 | Sony Network Walkman NW-E005 MP3 Player
Format Error
I hade just that prob. "format error" used to display. I did this:
1. dwl sonicStage (free)
2.- in the walkman went to menu/initialize/format
then displayed a confirmation screen, I confirmed
it displayed "formating...... COMPLETE"
3.- THEN plugged into the PC and transfered songs with Sonic
and it worked!
Jan 16, 2008 | Sony NW-E003F MP3 Player
Error code:00007180
I have this problem too. Found that if you go to the folder that has the music file in it, right click on each problem file and select 'open with -> " and choose Sonic stage, then it will import the file. Next problem may be that it imports it with 'unknown' as the file name but if you then right click on the file within SonicStage and select 'Get CD info' it will find it. Tedious if you have several dozen/hundred files that won't import I'm afraid...
Dec 07, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Sony Net MD Walkman MZ-N710 Logo
959 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
