Question about Webroot Spy Sweeper (spysweeper) for PC
Cannot enter keycode
How can I enter the keycode from the back of my install guide which has letters and numbers when the window asking for it will only accept letters?
    Genius:
  • 1,447 Answers
Try pressing numlock key on your keyboard and retype keycode.
update me if that doesnt help
Posted on Apr 23, 2008
  • chbreshears
    chbreshears Sep 11, 2012
    That didn't work for me. I tried with or without the numlock. I also tried using the numbers located above the letters. Still won't work
Pendrive install ridata
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt.
To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter.
Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive.
In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter.
As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
Oct 03, 2013 | Computers & Internet
Remove wat could not solve my window is not genuine build 7600 problem give me another aolution
Windows 7 Build 7600 by default will not allow you to do an upgrade install.
This how to will describe the process needed to upgrade from Windows 7 Build 7100 to Windows 7 Build 7600 with out doing a clean install.
Download the ISO as you did previously and burn the ISO to a DVD.
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value of 7100.0
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
Create a copy of your Windows 7 ISO file on removable media
Sep 27, 2013 | Compaq Presario CQ62-209WM Athlon II X2...
Installing My Invoices & Estimates and they are asking for a Seriel number
You are being asked to enter the keycode shown somewhere in the product documents.
Feb 04, 2018 | Avanquest My Invoices & Estimates Deluxe...
I tried to put 3 different codes into my ford focus radio after having recharged the battery and after entering the 3 sets of numbers that i found on the top of the radio it started counting down,,,can...
Good Day Konnie!
Try code 6151
To Enter the Security Keycode for a Ford
1. Switch the ignition ON using the key
2. Switch Radio ON - Display Shows CODE with "-------" flashing
3. Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
4. Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
5. Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
6. Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
7. If the display now shows the correct KeyCode number then Press Preset Button " 5 " to Enter
Please do rate my answer.
Thank you for asking Fixya.
Aug 06, 2011 | Ford Car Audio & Video
I would really like the unlock code for the original Fate but everytime i buy it it says its invalid. what do i do?
Entering the Keycode but nothing happens and I cannot continue
Key has not been correctly entered. Do not enter any space anywhere in the key.
Delete the full key with BACKSPACE and re-enter. Check for CAPS not being active and always enter the “-“ in between the digit/letter combinations
hope it works:)
Feb 04, 2010 | JoWood Productions Fate for Windows
How to set up my ssid security on my router
The first step is to open a internet browser window, in the address bar type 192.168.1.1 hit enter.
You will see a small window asking for the user name and password. This is the name you gave the router when it was installed and the password you issued during installation. Enter those and you will see the Belkin settings. Go to wireless security, choose a security level and either it will give you a security pin with the correct number of digits and letters or it will ask you to choose your own security numbers. Put in the security code of your choice, hit save settings and exit out.
Oct 10, 2009 | Belkin Security
I dont understand what it is telling me to do when it says please enter the code found on back of the manual or cd case
ok on the back of the install cd or the user manual there will be something that looks like this either just numbers or numbers and letters like this (5842-5468-6332-8201) (34d8-91re-601h-h62x) something like that find that and enter those lines into the box that its asking for
Oct 07, 2009 | Electronic Arts The Sims: Life Stories for...
Compaq Presario SR1740CF-ER938AA Product Keycode Not Valid
Is that the original cd came off on the box when you buy it. If yes it should be ok.. If not the the cd is wrong..there is no way you can use the cd key anymore. you need a new OE with cd key.
Jul 24, 2009 | Compaq Computers & Internet
Webroot Spy Sweeper (spysweeper) for PC Logo
331 people viewed this question
Top Webroot Computers & Internet Experts
Coss
Mike
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
