Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Power button doesnt shut down
Hi, put a new board/cpu in a hp 515n pc but the case just has a single line plug in adapter for motherboard power,hd, powerswitch , i try to rewire this so i cound use new board got to work except wont power down. the other board is one where it has single plugs like pw, hd, ect. are separate is there an adapter to fix problem. or something..
  • misfitgrave Apr 07, 2008
    hummm.. interesting will try..
  • E-Machines Master
  • 13,434 Answers
I would recommend replaceing the powersupply.
Posted on Apr 06, 2008
  • Ekse Apr 07, 2008
    you said you made changes into the current powersuplly - rewired, id really recommend agains that and get a new psu.
SOURCE:
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
Tip
AC adapter connectors
<a>HP, Compaq, Toshiba a</a>nd some others have problems with their AC adapter connectors on the motherboard. This is because they are not secured to the motherboard very well. They are just soldered to the board by the adapter leads. This puts stress on the leads whenever the plug is bumped or from plugging and unplugging the adapter. The adapter connector will, over time, become loose. The adapter will then not charge the battery, and when the battery becomes weak, the system will not power on. Some times, the unit will power on, but will shut off if the adapter plug is wiggled. If you continue to operate your system in this state, heat will build up from arcing at the ac connector and will burn the motherboard. If not repaired, the system board and CPU could be damaged beyond repair. Replacing the motherboard is then the only option<span> This could cost $350 and up. So the word is </span><span>GET IT REPAIRED EARLY</span>
on Apr 25, 2011 | Computers & Internet
Gateway MS2274 Laptop has a black screen and not booting. The power indicator comes on and all you hear is the fan and soon afterward will shut off; no hard drive LED. Tried removing the battery and...
Sounds like a severe hardware problem concerning your laptop's hard drive. I suggest you contact Gateway customer service to check on your warranty - your laptop is, simply put, broken. The best approach to repairing it is not to fix it yourself in this case.
Mar 13, 2011 | Computers & Internet
I have an HP Pavilion dv 6000z. I had shut it down, tried to power it back up. It will not do anything. Some of the blue lights come on for a short period,then it is completely dead. It has happened once...
Look at the area where you plug the AC adapter in on the side of the computer. HP puts a little lite there or it lites up around the area where that plugs in when power is present. If there is no lite indicating power then you AC adapter is not working and that coupled with the battery being dead is causing your problem. Your other options are to remove the Hard Drive, Ram and CDROM units and see if you get power back. If you do then you know your problem is a short in one of those. The computer should start to bios with those items removed. If it does then replace one piece at a time until it stops responding and you have identified the problem. The other problems that could cause this dead PC symptom are a blown power circuit, requires a new motherboard, a burned CPU, requires replacement of CPU which is normally a new Motherboard in an HP because it is soldered directly to the board. Check the power supply AC Adapter first as this is the most common problem.
Feb 21, 2011 | HP Pavilion dv6000z Notebook
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Apr 19, 2010 | HP Compaq Presario SR1110NX PC Desktop
What replacement backup battery does the pavilion
Hi, most motherboards that I have fixed etc... have used the 3.0V CR1620 Button Cell Battery which is easily available and cheap!
Jan 05, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Computers & Internet Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
