Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side: Ice Maker Issue
Our Ice Maker is not making ice but once a day. The ice is all of sudden clear. What is causing the ice maker not to make ice and why all of sudden when it makes a couple of cubes the cubes are clear?
  • markm687 Aug 29, 2008
    Freezer on the side by side GS 22 model, not keeping food frozen on top portion of freezer and icemaker not making ice. Defrosted freezer cleaned it inside and outside in the back.Double checked the water and all is working. GE is just about two years old. The Refigerator side is cool but not cold. Raised the temp on both sides but there is little or no change at # 8 now.
  • 74 Answers
Is the freezer working at the correct temp ?? Is the ice maker feed pipe blocked ??
Posted on Aug 28, 2008
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    My standalone ice maker is making very small amount of ice
    First off, check that the water inlet line is clear.
    Once on a refrigerator ice maker, the part of the water inlet hose inside the freezer ha a solid chunk of ice blocking the flow.
    Aug 11, 2014 | Kenmore 51lb. Clear Ice Maker
    Uline Echelon Ice Maker P1 error code
    P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
    Jan 17, 2014 | U-Line Icemaker
    GE Profile Model PSS26LGSC Ice maker not working
    Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
    Apr 07, 2013 | GE Refrigerators
    Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
    Good day,
    The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
    More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
    If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
    Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
    No ice
    Check whether the water is reaching the ice maker. If something is blocking its way get it cleared. Once it start taking water it should produce ice.
    Apr 20, 2010 | Whirlpool GS6NBEXR Side by Side...
    GE side by side refrigerator. Ice maker has a
    remove and clear ice. if it happens again change water valve it might be leaking
    Feb 12, 2010 | Refrigerators
    Ice maker will only cycle once then it goes to off position . It stop working due to ice build up in supply tube. I removed the ice maker and ran hot water over unit to clear out the ice that was lodged in...
    That bar your talking about goes to the full up position just before the end of the harvest cycle then falls right at the end of the cycle. But on a good day it barely drops. Characteristic of that ice maker.
    If you ran water over the ice maker try these 2 things.
    1. Remove the ice maker and leave it on the counter for about 2 days to completely dry out. Then re-install and try again.
    2. If no luck, hang a small weight to the middle of the wire to see if it will drop on it's own.
    3. If no luck, you'll have to replace the ice maker. However,
    if your commited to buying a new ice maker, first snap off the front cover and look for interference where the wire goes into the ice maker. You can actually remove the whole solid state front end by removing the 3 screws that hold it on and make a more detailed check.
    P.S. pull the wire out of the ice maker before this last step. It simply pulls out.
    Oct 28, 2009 | Whirlpool Freezers
    Profile ice maker stopped making ice
    ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
    Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    292 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
