Question about RCA D61W20 61" Rear Projection Television
Doesn't stay on
Power come on and off RCA D61W20B chassis ITC222
  • John Banach
    John Banach Apr 05, 2008
    i have a different model 27wl46 and the power keeps tripping n will not power on
    Genius:
  • 2,920 Answers
Power supply is bad needs replaced
Posted on Sep 03, 2008
Unit requires several power up cycles before it stays on.
It could be the CP150, cp120 and CP114 if you have the ITC222 or ITC222A chassis. But cant help further than that without knowing the model number of your RCA
Aug 20, 2011 | RCA Televison & Video
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Trouble turning tv on
sounds like bad capacitors on the RCA itc222 chassis.Need the model number of your set to help
Jul 21, 2009 | Televison & Video
Wont stay on after power is hit
Hello, I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 30, 2009 | RCA D52W19 52" Rear Projection Television
Television will not power on after power surge
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 27, 2009 | RCA D52W19 52" Rear Projection Television
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
RCA HDTV chassis # ITC222 will not come on.
most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Nov 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
No picture when the power button is green
Can you look on the rear panel and post the Chassis number to your set as that model has used 3 different chassis designs. They have a ITC222, ICC222 or a ATC series. If you can respond to this same post with the chassis number I will be able to assist you with the problem
Jul 11, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D61W20 61" Rear Projection Television Logo
201 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
