Question about Tascam 2488 Portastudio Multitrack Recorder System
Using the effects on the 2488 mk 11 for vocals
I am having a problem getting the effects to work on vocals.When I go threw the manual and put in guitar multi effects I have no problem.But when I use the microphone on track one I only can get guitar effects.Can you give Me a basic instruction(like the manual has for guitar and lead guitar)on how to record a vocal track with just reverb?Thank Taf
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Posted on May 19, 2008
6ya staff
SOURCE:
The lights are on but nothing is coming out,, no voice no guitar nothing???
Double check all your settings, then do a reset. If that doesn't work it will need to go to the shop. Here is the Digitech contact page to ask them or to find a service center-
Support DigiTech Guitar Effects
Apr 01, 2015 | DIGITECH Vocalist Live 5 Vocal Harmony and...
Effects quit working on Acoustic AG30 amp. what are the likely problems and costs to repair?
I am guessing it is solid state? If it were tubes it would be an easy fix but the solid state amps are very hard to diagnose and repair. I think the Guitar Center has a repair department and they probably know the trouble shooting steps. I am guessing it is a board, but the way to trouble shoot would be to know how much current should be flowing to individual leads. I do not have this information, but you will need a multi meeter in order to start the process. No reputable repair shop should charge you any thing to give you an estimate.
Oct 09, 2014 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
I have lost my user guide Zoom 2100 guitar
Try this link:http://www.manualnguide.com/download/manual-guide/zoom-2100-guitar-multi-effects-user-manual.html Hope this helps.
Mar 13, 2010 | Music
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
NT3 or NT1A?
Either mic will work for piano, vocal and guitar.
Jan 02, 2009 | Rode NT3 Professional Microphone
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
230 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
