Question about RCA DRC8320 DVD Recorder/VCR
Dvd player wont work
Every now and then, the panel doesnt light, open and close wont work, loading comes on the panel and nothing happens it just stays that way for 10 minutes. If it does load "interface error" come across the screen and says to turn the power off. The power will not turn off from any buttons, so you have to pull the plug. The dvd wont play and the disc wont eject and yet at other times it works fine.
  • farmeral Apr 13, 2008
    I have same problem. The panel doesn't light, open and close wont work,
    loading comes on the panel and nothing happens it just stays that way , wont respond to buttons being pushed on unit or remote. If it does load "interface error" come across the
    any buttons, so you have to pull the plug. The dvd wont play and the disc wont eject and yet at other times it works fine. I left it unplugged overnight but no change.
  • shad7 Apr 13, 2008
    have the same problem. Sometimes VHS tape gets stuck when trying to eject, sometimes open/close won't work. Can't get anything to work the last couple of days except to see it say "interface error, turn off the power". I also left it unplugged overnight but nothing has changed.
Same exact problem as above three. Now what?
Wish I could hear how others resolved the issue - or did they? It's just over a year old.
Posted on Jul 10, 2008
I have a dvd stuck inside the player and when I hit the open button on the player and on the remote nothing happens. The screen on my TV says open but nothing is happening and it doesnt even do that much...
You'll have to take the case off.
Six screws hold the case on. UNPLUG the unit and take the back off. There's no other way but it only takes five minutes.
Mar 02, 2011 | NexxTech DP3222 DVD Player
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
I put an HD-DVD in my player but it keeps coming back out.
Temporarily you can hold the lid closed with your hand and press play and leave the lid after it loads the disc. But for permanent solutuion you will require to repair its lid switches,
Aug 22, 2009 | Toshiba HD-A30 HD-DVD Player
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
Hairspray DVD in my player
i\'d say leave this thing out the door because my emerson did the same except mines a VCR
Feb 14, 2008 | Emerson EWD2203 DVD Player/VCR
Doesnt play
Open it up, look for a loading belt (black rubber band about 2 cm diameter) and replace it.
Jan 21, 2008 | Philips DVD 622 DVD Player
RCA DRC8320 DVD Recorder/VCR Logo
288 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
