Question about Braun WK600 Cordless Electric Kettle
Red light's on... but no hot water!
Red operating light comes on but element doesn't heat the water
I have a cordless, but dont know the model. The red light comes on but does not heat the water. Please advise, if the element needs replacing and who repairs these kettles in Durban, South Africa. Tks Heather I have the Braun electric kettle pictured, presumably the WK600 model. My problem is not identical, but similar. The kettle worked perfectly (fewer than a hundred boiling sessions) until suddenly the two side red lights refused to illuminate and coincident to that the heating element stopped working, although an electrical sensing device indicates the base charging unit is receiving power. I've disassembled the bottom of the pot but can find nothing obviously wrong -- in fact, it looks brand new. I'm left wondering if one bulb burns out does this break the circuit to the heating element or is a different critical electrical component I can't see malfunctioning? If a solution is not available that I can implement, does anyone know of a repair shop to recommend, the cost for which won't approach that of just buying a new unit? Thanks. -- D. J.
  • 3 Answers
Just a bit of clarification; the lights and heating element are both downstream of the thermal protection ( I had mine apart and had a look). Therefore the lights would be off if the thermal protection had kicked in.
Lights on but no heat means element has a problem. Could be loose wire but more likely burnt out. If you have a tamper proof TORX bit you can take the bottom cover off and check for continuity through the element. Isolate the lights from the element so your meter is not accidentally seeing continuity through the lights.
Posted on Apr 12, 2009
  • 3,037 Answers
I think either the heating elements are bad or from moving it, something knocked loose like a small wire or piece of metal between the coils and the power supply. see if anything may need to get soldered, if everything looks fine then I would try and buy some new heating elements and put them in myself since it wouldn't be worth someone else doing it I believe. Please keep me updated, thank you
Posted on Apr 05, 2008
  • Benjamin Patri
    Benjamin Patri Apr 05, 2008
    have you checked the fuse, I would have assumed that you did this initially
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    Were you able to fix this problem or do you need more help with this. Please let me know, I'll be glad to help.
  • Braun Master
  • 19,396 Answers
It is the heating element, probably is just a contact to be re-soldered.
    Genius:
  • 3,422 Answers
HI,
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan Apr 05, 2008
    Scroll down and on the right side you will see a "REPAIR SERVICE" feature.In that you have to enter your area zip code and you will get a list of service center in your area.
    Or you can give me your zipcode and i'll try to find out one for you..
Is the red light on a bosch ae125 supposed to come on when hot water is flowing
red light shows when power is applied to elements, and water is heating
Sep 09, 2014 | Water Heaters
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
There is a red light visable thru the glass top on the left rear of the cooktop. cannot find this light anywhere in the book. it is on and has never come on befor
Yeh,
I ve seen this before.
Try turning on one buner at a time. Make the element red hot!. If one does not get red hot. make a note of that switch.
Some stoves create a way for a technician to know which switch is shorted and uaually it is the one that doesn't get red hot.
If all buners are red hot , preheat oven for 350 and wait. it should take 5min to heat up oven. if oven not hot ,one of the elements is blown
Aug 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
3 of 4 heating elements on Kenmore glass cooktop do not heat properly. They come on and then cycle off and on and never reach a cooking temperature. Only one of the 4 works properly. I believe the...
this might be normal behavior is the unit still heating and boiling items? has the unit worked differently in the past?
see below
Why the smoothtop radiant cooktop element cycles on and off
  1. Save as PDF
  2. Share
Table of contents
Does the radiant heating element cycle on and off?
  • The surface cooking area may glow red when a heating element is ON.
  • Some parts of the surface cooking area may not glow red when a heating element is ON.
  • The warming zone element (on certain models) will not glow red.
  • Radiant elements have a limiter that allows the element to cycle ON and OFF, even at the HI setting, to prevent damage to the ceramic cooktop. This is normal operation.
  • The radiant heating element retains enough heat when off to provide a uniform and consistent heat. The surface will still be hot even though the element has cycled OFF.
  • Cycling at the HI setting is normal and can occu
Feb 26, 2018 | Kenmore Kitchen Ranges
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Mar 30, 2009 | Maytag PYE2300AY Electric Dryer
Nov 06, 2007 | Kitchen Appliances - Others
Braun WK600 Cordless Electric Kettle Logo
1,048 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
