Question about LG DLE5977 Electric Dryer
Cooling light on?
Dryer stops early and clothes are never dry. Also cooling light is constantly lit???
  • spcmast Apr 27, 2008
    I have the LG TD-C70042E and now have the same issue, the dryer doesn't heat up and the cooling light is constantly on, regardless of drying setting. At first the tumbler would not turn and the repair person came out to fix it and replaced a small cylinder part that plugs in just above the motor, I can't remember what he called the part.
    I noticed that he pushed a combination of the Power button and a few of the Additional function buttons, i.e. the High and Low Temp buttons, but didn't specifically see what he pushed. This allowed the tumbler to spin, but didn't add heat. I don't think he reversed what he did.
    Luckily he is coming back next week to fix the noisy drain motor, but I thought I would check this forum for some interim help.
    Thanks in advance.
  • Anonymous Mar 25, 2014
    stopped drying clothes, no warning, just cool air....
    Champion:
  • 210 Answers
The cooling light is always on, it flashes when it is in that part of the cycle, sounds like he put it in to a test mode. Was it a thermistor that he changed?
No heat, sounds to me like a thermostat might be blown. Call the guy back, if you haven't already.
Sgt 48
Posted on May 31, 2008
  • 489 Answers
You may have a problem with the motor not working.  Have a qualified LG technician check this out.
Posted on Apr 28, 2008
6ya staff
SOURCE:
Dryer stopping very early and clothes not dry
try putting it in manual timer mode
Sep 19, 2014 | Bosch Dryers
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Dlg5988s dryer does not dry clothes
what is your model number is then we can get started then okay
Feb 07, 2013 | LG DLG5988 Gas Dryer
I have a Whirlpool Calypso Electric Dryer with digital touchscreen selections. However the only selection that will remain lit and useable when pressed is the delicate cycle. The time for that cycle can...
Robyn, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Robyn), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Dryers
My dryer stops drying after 10 min. All the lights flash on the right hand side. I've tried different drying settings and different amounts of clothing. Nothing works. What's wrong?
My dryer does the same thing. Additionally, it is not heating what so ever. Clothes are cool and damp, and heating vents at back of dryer are cold to the touch.
May 11, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
LG DLE5977 Electric Dryer Logo
1,465 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
