Question about Samsung PS42P2S 42 in. Plasma Television
This unit is a B mobel PS42P2SB
Unit has a PPR2200 media station(tuner) which is used tp connect several sources to. It appears to have taken a dump this morning it switchs on and off rapidly repeatedly. Yhe display connection is DVI-I. I am in the US and need a replacement unit for the media station that will accept DVI-I. Maybe any adapter to RCA component would work..
Any info would be greatly appreciated
  • Anonymous Apr 17, 2009
    That's the switched PSU unit that is designed to do this. For me it was the diode short circuit along with the resister blow as a result.
    replaced both and all up and working again.
Samsung PS42P2S plasma tv when you switch on from cold sound crackles and pops from the speakers for about 30 seconds then its ok, when you switch off and on when tv has been on its ok, just if you leave it off for a while. anybody know whats wrong.
Posted on Dec 20, 2009
  • kxj77 Jan 29, 2011
    I have a similar problem with the ps42p2sb. When the system is turned on thee is a loud hiss and cracle from the speakers. This used to disappear as the unit warms up, but over time it is getting progressively worse. I have tried new speakers but the problem pesists. Does anybody have a fix?
I Have been given a samsung plazma tv Model No: PS42P2SB but that is all. I have no Media Station PPR-2200 what can I do to get this Tv up and running.?
Posted on Jun 21, 2010
Looking into same problem found main capacitor 450v 330uf cap domed and two 10v 1500uf caps so far ordering parts will update
Posted on Apr 19, 2008
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
Cheryl j11 radio beeps and says t p lost
Chery J11 radio beeps and says TP Lost
The Short Answer
This can be pretty annoying as the beep occurs every few minutes. The cause is that the advanced features of the radio are searching for broadcast traffic information, and can't find it.
Generally, only some of the radio stations in major cities carry traffic information, so this feature may not be very useful to you anyway.
To disable the beep, press the TA/AF button on the radio for more than 2 seconds, and you should see AF OFF appear on the display, meaning that the Traffic Announcement Alternate Frequencies feature is no longer searching for (and not finding) traffic information.
Unfortunately, the Chery radio manual doesn't fully explain this.
Traffic Information (TA) Control
Some stations broadcast on the FM waveband have a TP code to signify that they carry traffic programme (TP) information. This is part of the RDS (Radio Data System) used on FM.
Activating traffic announcements
Before you can receive traffic announcements (TA), you must press the TA button. A TA display will appear to show the feature is switched on.
Note: On some units a short press to reach the TA feature.
If you are already tuned to a station that broadcasts traffic information, TA or TP will also be displayed. Otherwise the unit will search for a traffic programme and display TA SRCH or TP SEEK while doing so. If it cannot locate such a station, Not Found or NO TA will be displayed.
Info from
TP lost
If the TP signal of tuned station is lost after 30 seconds, an automatic TP seek for the next TP station will be performed. If no TP station is found, the unit will remain at the current station and display "TP LOST" for 2 seconds, and emit a beep.
TP seek will be performed periodically few minutes until a TP station is found.
Info from
Posted to
audio guide 1 cg3508en 01 2006
2011 Chery Chery Solving Car Problems chery
Sep 18, 2013 | Car Audio & Video
Samsung PPR2200
Change 4 capacitors (10uF) in sound session
Feb 28, 2010 | Televison & Video
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Denon AVR 1910 - no sound from v-aux or tuner
The tuner is the best source for testing audio issues from a receiver since it uses an internal source for audio. This problem could be two separate issues. Check the tuning in the tuner to make sure it is on a station that you are receiving. The newer Denons will not play any audio is the station is not coming in. Be sure your antenna is connected and tune the station to one that comes in clear.
What source is hooked up to the V. Aux? If an iPod it is common that the volume on the ipod is down .
Nov 22, 2009 | Audio Players & Recorders
How do you switch between the front aux and the line in on the back of unit
According to the manual:
"In the case of a CD/MD changer or SAT tuner being connected: when "source" is pressed the connected device (MD, XM, or SR) will appear in the display, depending on which device is connected. Then if "MODE" is pushed you can switch the changer or change the SAT tuner band."
Mar 24, 2009 | Sony CDX-GT520 FM / AM Receiver
Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Mar 16, 2009 | Aiwa Audio Players & Recorders
NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Nov 22, 2008 | NAD 712
Tv samsung plasma
If it has not tuner/antenna input then it is just a monitor. At that point you will need a cable box,sat box or something to provide a picture scource to it.
May 26, 2008 | Televison & Video
Kenwood kvt 715 screen saying disconnected cable found
same problems would like it if you could tell me how you resolved it, many thanks
Aug 29, 2007 | Kenwood KVT-617DVD Car DVD Player
Samsung PS42P2S 42 in. Plasma Television Logo
936 people viewed this question
Jerry Greenberg
Jerry Greenberg
