Question about Acer Aspire 5100 Notebook
Laptop keyboard settings
I have attached a keyboard via usb port to type this There is some setting on my keyboard that changes some of the keys to numbers. example the key for k now types 2 etc.
As 'ziau' said, it was nothing more than the 'numlock' key. I had pressed it when fixing a problem with my touchpad.
A 'fix' sure is satisfying 'after the fact'!
Thanks, ziau!
Posted on Apr 20, 2008
  • 123 Answers
Is that all??your 'k' turns to '2' coz ur 'numlock' has enabled..to disabled that thing just steadily press the 'fn' icon on ur keyboard between 'ctrl' and 'windows key' and press the key that has the 'num lk' icon that were inside a box..if im not mistaken that thing is in the 'end' key..as simple as that..
Posted on Apr 06, 2008
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Enable keyboard
First, make sure it is plugged in. If it is a USB type, try the other USB ports on the computer to see if one or more ports have failed.
Still no luck? Try differen USB ports each time you boot up. During the boot, enter the computer's BIOS or Set Up area (usually pressing DEL, F1 or some other key). Check for setting regarding keyboard and keyboard type. Make sure they are enabled. If nothing works, the keyboard may be broken - not disabled. Try with another keyboard instead.
Apr 09, 2014 | Computers & Internet
Keys c v b are not responding - I've changed the batteries
It is the Keyboard or Word Processing program. Not a Battery. Try to use a USB Wireless Mouse/Keyboard set via the USB ports to see if you still get same condition occurring. If this solves the problem, you know the Keyborad is defective.
Jan 08, 2014 | Computers & Internet
Opens new window when you click on a browser link
You may try to attach a USB Wireless Mouse and Keyboard set and bypass the system you are currently using. If it is a Keyboard only problem, try a USB independent keyboard and again bypass the computers unit to see if the problem still exisists.
Jan 04, 2014 | HP ProBook 4430s Notebook
Keyboard keeps changing to control functions on the keypad instead of normal keyboard usage. We keep resetting the keyboard settings to default but keeps going back. Do you know if this is a...
High probability that this is just a keyboard key failure. Attach an Apple keyboard (or a generic keyboard) to one of your USB ports. Use it for a while. If you don't see this behavior, then the problem is in your keyboard, which is easily replaceable by an Apple tech.
Mar 30, 2010 | Apple iBook G4 Mac Notebook
Keyboard will not type. Function keys work when I boot up plus keyboard works if I attached to my laptop. It is plugged into a USB port..
In your BIOS, check your security settings and if for some strange reason your keyboard is not enabled upon startup, enable it. Otherwise it could be a faulty keyboard.
Nov 19, 2009 | Shuttle AB45 (SHUTAB45) Motherboard
Fn key is broken
im afraid not, unless you can pull the key (im assuming its just the key) from another keyboard. note that you can change the display settins (in XP) through the desktop settings
Mar 26, 2009 | Acer Aspire 5672WLMi Notebook
Apple key no longer working
The Kensington keyboard is being recognised as a PC-style keyboard, and the software has swapped the action of Apple (Command) and Alt (Option). Go to System Preferences > Keyboard and Mouse, and set the Modifier keys correctly in the Keyboard panel.
macs2u
Jun 16, 2008 | Kensington Comfort Type Wireless Optical...
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
19 key Numeric keypad with 2 usb ports
You better consult your hardware manual.
If there is no manual Try checking your regional language selection in control panel. Check your MS word configuration go to: Tools > Options Check your settings for keyboard or input device.
Oct 10, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Acer Aspire 5100 Notebook Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
