Big Screen TV Picture.
I have a 60" Big screen TV. The picture has gotten smaller, and you can't hardly hear the words. Can you please give a general idea what wrong.
  • 81 Answers
Sound ....pcm or digital may have been changed. or sound board need replacement.
Posted on Apr 05, 2008
  • rick paz
    rick paz Apr 05, 2008
    did that helped?? you can try me at pazinc@yahoo.com
BIG SCREEN TV WILL NOT COME ON
YOU LOST VERTICAL DEFLECTION THIS IS NOT HARD TO SOLVE
Dec 25, 2009 | Televison & Video
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Big screen 45in tv
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Or you may have a picture tube going bad.
Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
60 in.rear projection Philips Magnavox
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Nov 07, 2007 | Philips Magnavox 9P6034C 60" Rear...
Projection picture problem
I am having the same problem on my 9p5031c101, ver interested in the solution!!! sjoney@sunnenlink.net
Aug 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
