Question about Philips 20DV6942 20 in. TV/DVD Combo
Picture is to big for the TV
On the top and bottom of the the screen on some channels the picture is to big is there some way to fix the problem?
  • Dmaster Apr 05, 2008
    Say you are watching CNN and it has the scrolling stuff across the bottom of the screen you can barely see it
When i turn on my tv just only half screen appear on my TV screen, do u have any i dea to fix this problem.
Posted on Aug 04, 2008
SOURCE:
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
I have a samsung lcd 650 series tv and a dish network remote. I can use the remote to change channels and control power and volume to my TV. I cannot change the picture size and the picture on most...
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Oct 27, 2010 | Samsung AH5900092W Remote Control
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
Picture is to big for screen
Menu go to setup,go to reset,well be back to factory setting.U will have function to view mode,not than ur video backlight board have problems.
Apr 30, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Picture to big for the screen
sounds like you have the zoom feature on. use the left and right arrows to set the picture.It will also set the picture format also.
Nov 07, 2007 | RCA HD52W59 HDTV Projection Television
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Philips 20DV6942 20 in. TV/DVD Combo Logo
264 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
