Hp psc 1300 printer cartridge stalled problem message. WHen finished printing page will not eject fully and then get that message
  • Anonymous Sep 09, 2008
    Trying to print only one page, will print page then feeds another page then catridge will stall. "Printer Cartridge Stalled" error message is displayed.
I had the same problem with hp psc 1350 all-in-one. Number of the cartridge 56, 57. I tried to get some ideas in the local hp technical support - no help. So I opened the whole think, cleaned the contacts on the cartridge and on the trolley, Then I pressed the smaller tape you could see on the left side ( which is responsible for passing of the data ) to make sure that there is no problems with contact. After this procedure from some reason the amber light stoped flushing.
And one more point if you press the first and second buton on the left side you get no 1 on the display and both amber diode start flushing. Then you can open the door like you would replacing the cartridge and then close them again.
Hope that this would be of some help.
Jan
Posted on Jun 24, 2008
The 'check print cartridge' light keeps flashing on my HP printer, so I replaced the cartridges and everything else i could think of such as restart my computer, temporarily disconnect the printer, etc. the light continued to flash. I also tried resintalling the printer software. Any ideas??
Posted on Apr 30, 2008
Psc 950xi printer hp
You may be doing everything right except the very last thing.
After replacing the cartridges, your product display will ask to do a cartridge alignment. Press ENTER on the control panel to align the print cartridges.
You must allow your printer to finish this procedure.
Dec 30, 2009 | HP PSC 950 All-In-One InkJet Printer
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
How to stop printing test page every time I turn on my printer
This is an aligment page.When printer print the page just follow the instruction on page put it on the scanner glass and finish the aligment.If your color or/and black cartridge is empty or clogged the aligment is not compete and printer will print this page every time when you turning it on.If your case is that just replace the cartridge and finish the aligment.
Nov 04, 2009 | HP PSC 1410v All-in-One Printer
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have an HP PSC 1300 Series, eulatory Model SDG6B-0303. When printing a document today, it said that the black ink cartridge was low, so I changed it. Then, when I tried to resume printing, it said the...
Try removing the printer then reinstalling it. If you have a disc. I think they have discontinued driver downloads for HP PCS 1300 and 1400. Do not remove it if you do not have an installation disc.
Nov 22, 2008 | HP Office Equipment & Supplies
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Message Ink Cartridge stalled
the machine needs servicing, something is causing the carriage to stall
Nov 04, 2006 | HP PSC 1350 All-In-One Thermal Printer
847 people viewed this question
k24674
jasbo
jasbo
