Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
My 36" toshiba has a black screen when i first turn it on,then comes in after30 seconds or so is it a fuse? thank you
My 36
  • patricia myers Apr 05, 2008
    my 36 inch toshiba has a black screen when I first turn it on, then after about 30 seconds it will come in. could this be a fuse? thank you.
    Genius:
  • Philips Master
  • 1,673 Answers
If there was a bad fuse, then the set would be dead! A fuse works or does not work.
There may be a fault with the power supply or some other section that is having a delay to start up. This is normaly due to some components starting to fail.
In the case of an LCD set, a common fault is the back plane lamps or back plain power supply starting to fail.
Jerry G.
Posted on May 16, 2008
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
Big black box across the screen towards the bottom.
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Dec 13, 2008 | Toshiba CF36G40 36" TV
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
36 in toshiba
please model would want would say in a television toshiba to me cf2048, as I can abrir a little the vertical one because it has black strips in both sides as of centimetre of width, thanks, Gerald
May 17, 2008 | Toshiba 36A40 36" TV
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
Toshiba telivisions picture brightens
It has a bad solder connection inside the set. Requires qualified individual to find the connection and resolder it.
Jan 02, 2008 | Toshiba 36AF62 36" TV
No Picture, No Sound
It could have been a coincidence or maybe excess windex fell down in the push buttons assembly thru the botton edge of the frame creating a short and blowing a fuse ,if you are familiar with tv service checking the fuses will be a good place to start,if you find one and is black it means you have shorted component ahead,If you are not too familiar with tv service be safe and call for assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 12, 2006 | Toshiba 36HF72 36" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
