Question about Frigidaire ATF6000ES Front Load Washer
LOC error I keep getting the LOC error message when I try to start the machine.
  • 3 more comments
  • Anonymous Apr 28, 2008
    This just started after 2 years of good service. Just started down the research of what is wrong.
  • DNicho9164 Oct 28, 2008
    The LOC error comes up whenever you push any button on the control panel, and the little door lock button never lights. Door secures closed tightly, but nothing changes.
  • elsie0726 Nov 19, 2008
    I keep getting the LOC error message when I try to start the machine. How can I fix this problem
  • Anonymous Dec 04, 2008
    Door is shut, but keep getting LOC display no matter what button you push. Machine wont start, how can I fix this. Is there a reset button?
  • MGPC Jan 26, 2009
    My machine is about eight months old. The lock didn't work at first, then it fixed itself. This week it stopped mid-cycle when the door unlocked all by itself. Now the door won't lock at all.
That can be the door lock with out knowing more its hard to say
Posted on Apr 26, 2008
I have a frigidaire front loading washer and when I try to start it, the error message reads "LOC"
Good Afternoon Friend, thank you for allowing me to assist you!
If you are getting an error code LOC on your Frigidaire washer, it usually means that your control panel is locked. Let's attempt pressing and holding OPTIONS and SELECT at the same time for about 10 seconds. This usually does the trick. If not, you may want to try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Thank you! - Z
Aug 29, 2014 | Frigidaire Washing Machines
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
Flashes LOC and won't start
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in
Nov 08, 2012 | Kenmore Elite 45986 Front Load Washer
Cycle starts but shuts off. timer keeps running. when we press option select we get LOC. when we hold start/cancel button we get 5 beeps and ESE
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Message "LOC" Three beeps, won't door lock or start
You may have to remove the lower front panel to get to the tech manual. If the door latch isn't latching though nothing is going to happen.
Jun 15, 2009 | Frigidaire GLTR1670A Front Load Washer
Programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Dec 30, 2008 | Uniden BCT8 Base Scanner
LOC message
This sounds like a faulty micro switch on the door catch. Try pressing inwards on the door glass at the catch area whilst you press start and hold it oressed for a few seconds until it either starts or displays the error again, if the error shows it may require a new switch, the switch can be tested by bypassing it and joining the two wires together that plug onto the switch. The switch can be accesses by removing the dor seal from the outer most edge.
Jan 26, 2008 | Washing Machines
Kenmore Front Loader - LOC & Error Codes
You need to switch the machine off at the wall and leave it off for a few seconds. Open the door. Switch the machine back on again and close the door firmly. It should be o.k.
Aug 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire ATF6000ES Front Load Washer Logo
122 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
