Question about Viking VWH3048 Kitchen Hood
Viking hood Lights out
We have a viking range hood, similar to the VWH3048, the difference is ours has the 1200 blower. The other day, both of our lights went out. We thought it was strange that they went out at the same time, but we went ahead and changed the lights. To our dismay, the new lights didn't come on. Is this something that we can fix ourselves? Any ideas on what happened, my husband thinks that it is either a short or the sockets burned out. Any advice would be appreciated. Same problem my lights did the same thing, one bulb was dead I changed both still no light.
    Genius:
  • 1,665 Answers
Posted on Apr 05, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 05, 2008
    Check also each bulb-case wiring not to be burned at their edges.
  • 725 Answers
First Check your switch if you have power to the switch ...its the switch if no power then check you transformer .. if you have an ohmmeter you can also check the bulbs let me know if it helps...
  • Viking Master
  • 19,396 Answers
There is a short inside, you need to check wirings to locate the short.
  • Ginko
    Ginko Apr 05, 2008
    If you tell us the exact model we can try finding the wiring diagrams.
  • Ginko
    Ginko Apr 05, 2008
    Check for a short in the circuits right behind the lamps, or in the cables getting right to the bulbs. Also test the voltage coming to the bulbs.
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
Viking 10 inch hood lights out
It is more than likely the dimmer switch has gone bad and needs to be replaced
Nov 06, 2008 | Viking DTWL4848 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
VWH 3648 Hood
most of them you have to take the filter off. under the filter, there are some screws. take them out and then it should drop the motor and you will see the electrical.
good luck
Jun 21, 2008 | Viking VWH3048 Kitchen Hood
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Viking hood damper
Remove the blower and reach up into the duct through the back flow damper and put weather stripping on the 2 edges that are chattering, it will greatly reduce the noise
Dec 20, 2007 | Viking VWH3048 Kitchen Hood
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Viking VWH3048 Kitchen Hood Logo
410 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
