Question about IBM ThinkPad T43 Notebook
Intermittent loss of internet connection
I have a T43 TP 2668-C5U and it was working fine. Then one day all of a sudden I noticed that my internet connection goes out periodically. It happens when I'll be using the computer and then go away for a few minutes or hours and then come back to the computer. I had the modem checked as well as bought a new ethernet cord in case those were the causes and that did fix the problem. Another thing is that when this happens, the connect can be restored in any number of ways including, restarting the computer, restrating the modem, going to the network connection in control panel and "repairing connection," and sometimes just unplugging and replugging the ethernet cord from the computer. What is going on and how can I fix this? Is there some kind of diagnostic program I can run to determine the exact nature of the problem? Thanks!
  • bjs77 Apr 05, 2008
    thanks TampaNative. It's a good thought, but the thing is, it didn't used to be like that, so that's why I'm wondering what's up. I'm hoping there isn't something wrong with my network adapter. Is there some kind of diagnostic I could run to see if that was an issue? thanks again!
    Genius:
  • 1,027 Answers
You may want to check how often the modem renews license.
I had a problem with my modem but when I added a router or hub and set up my computers with a static addresses I no longer had that problem(I had to add a router because my ISP would not let me alter the configuration on my modem)
My nextel modem renews every hour.
Posted on Apr 05, 2008
    President:
  • 778 Answers
It sounds to me like an inactivity time out, like dial up ISPs do. Check that your ISP (internet service provider) doesn't require activity within a period of time before severing your connection.
Just a thought, and Good luck.
  • Frank  Fernandez
    Frank Fernandez Apr 07, 2008
    You're Welcome.
    All or most of the corrective methods that you mention in your first post lead me to think it may be your ISP resetting your IP (as it's surely dynamic and not static unless you're paying for a Static IP?) so you are having to re acquire a new network address more frequently than you're used to. You should be able to prove or disprove this by clicking Start > Run > typing "ipconfig" > and clicking "OK" , in the dialog box that appears your IP will be displayed and after your next event and reconnection check again to see if it's changed?
6ya staff
SOURCE:
How come I can get Netflix on 1 tv and not the 2nd tv I worked fine until yesterday it stopped on the 2nd tv but other sites work on it
Start by troubleshooting whether your second tv has an appropriate internet connection. I have found that with multiple devices connecting to the same NETFLIX account, often has intermittent connectivity problems attributed to the device connection to the internet.
Oct 27, 2014 | Roku 2 XD Streaming Player 1080p
98 dodge avenger p1391 code, had no start first with no code and replaced dist..didnt fix it..then replace crank sensor and that worked..ben running fine for a year..now all of sudden runs crappy and...
Check connections to crank sensor, then reset your comp by disconnecting your battery cables and holding them together. Make sure to have the code cleared as well.
P1391 (M) Intermittent Loss of CMP or CKP Loss of the Cam Position Sensor or Crank Position sensor has occurred.
Apr 14, 2013 | 1998 Dodge Avenger
I installed the wifi router 3 days back. Had some initial problems which i solved using the books in kit. However, speed was very slow. Next afternoon, speed suddenly picked up. It was perfectly fine...
Hello Ahmed,
This may have nothing at all to do with your router, but may be associated with your modem, or cable connections inside and outside the home, or even your ISP.
I recommend you check with your ISP for a service visit to ensure all is working according to specifications.
Feb 14, 2018 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
How do I download drivers for: Modem 7.12.15.50 for XP on IBM Thinkpad T43 2668; Also network card. I need to make a copy and transfer it to the laptop I am repairing, because it doesn't have an internet...
You can download it to a flash drive on another computer, hd of another computer and copy to cd, external HD if you have any available.
Link for modem
Link for NIC
Please note: these are for XP, XP Tablet 2005
They have the Vista version also.
Good Luck to you!
Nov 02, 2010 | Computers & Internet
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Internet connectivity - mouse related?
Purely coincidental, especially if your mouse was plug and play like 99% of them out there today. My guess is that you are having a totally unrelated problem with your internet. If I was going to troubleshoot it, I would simply remove the mouse and any software that you might have installed with it and then check the internet connection.
Oct 22, 2008 | Warrior 797146022002
Internet Connects but disconnects suddenly
Who is your ISP?
It seems you are experiencing intermittent connection. Bypass the router and check if the same problem exist when connected directly to the modem. If the internet works fine with the modem.then you have to configure the router correctly.
Aug 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
Intermittent connection to wireless network
Two possibilities to consider --
There are reports the combination of a hidden SSID and WEP/WPA encryption causes intermittent connections using Windows. Recommended solution to show the SSID instead of hiding it.
Second possibility consider changing the channel the wireless communicates on in the router from the often default 6 to 1 or 11 to see if you can avoid interference on channel 6. Try the other channel if the first does not work. Interference is not only from routers but can be from in house wireless phones and other devices.
Dec 22, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
219 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
