My Insignia TV will not turn on or off, it makes a chirping sound and the green light blinks. the only way to make it stop is to unplug the tv.
  • 81 Answers
It sounds like power relay control module
Posted on Apr 05, 2008
Tv wont come on
Did you try unplugging the TV? Also if that does not work then call the TV provider and ask them for help.
Mar 14, 2016 | Philips TV Tuner Video Capture PCI Card -...
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Power light blinks and TV gives chirping sound
It may be the power supply has failed, and or one of the board has a short in it. You will have to find out who services this model of set in your area. They will have to use board substitution to service it. It is possible that the parts are no longer available for this model. The service rep can tell you that.
Jerry G.
Jun 28, 2008 | Insignia IS-LCDTV32 32 in. Television
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
