Color off on TV
Color is off on TV - mostly purple & green. Only about 14 months old.
  • 81 Answers
Fluids need to be change
Posted on Apr 05, 2008
6ya staff
SOURCE:
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
My KDL-46NX800 is only a month old. Three days ago the colors have been all green, pink and purple, looking almost psychodelic. It stopped by itself and returned to regular color, and today it is doing...
Take this tv back where u bought it ask for a tv replacement.This tv have major trouble with it tv Tuner signal board.That the board,where the incomming broadcasting signal cable plug in and external devices plug into it.
Jan 14, 2011 | Sony KDL40HX800 40 in LCD TV
Dynex 32 lcd hdtv L32-10C color is flashing green and purple
Just go to the service center where you bought that tv ,cause its ,one year warranty period. just consult your tv to the costomer service personel.
Jun 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Purple lines scrolling, green in the middle, blinking on and off
Time for a new TV... Unless your really really really attached to that TV your going to spend more money on it then its worth to try and troubleshoot and repair it. Most of the TV's that come across my bench for repair that have developed lines and color splotches go into the recycling dumpster, they just aren't worth the time to repair as it usually comes down to a bad board or components that just can't be obtained to repair it. What most people don't realize is that once a tv is a couple years old there just isn't service parts for them anymore. The manufacturer keeps parts available until the warranty period is up on a model then its done for.
Jan 01, 2018 | Samsung DLP HL-P5663W 56" TV
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color coded Kenmore needles
Hi there, The different colors only correspond with the size of the needle. Green is actually a size 18 (110) needles which is basically as big as they come! your best bet would be to go with a size 11 (75) or 12 (80) needle. For the Kenmore color coding it would blue or orange respectively. Hope this helps
Dec 10, 2008 | Kenmore 15516 Mechanical Sewing Machine
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My mitsubishi dlp hd tv has color bleed and everything is purple and green after set warms up. What causes this to happen? What does it take to fix this problem. the set is only 15 months old.
This set has the problem of sucking up dust and scuzzing up the light engine, this causes purple and green spots, A good tech can disassemble the light engine and clean it, the cheap ones will change the light engine
Jan 30, 2008 | Mitsubishi WD-62827 62" Television
Open Questions:
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
