Question about EliteGroup P4VXASD2 Motherboard
Computer will not boot
When I turn the power on, both the CPU fan and power supply fan spins but the system does not "beep" and perform BIOS POST check.
If I then connect a power connector to my video card (Geforce 7100 GT), the CPU fan will not even start.
Is the motherboard fried?
  • robichj Apr 05, 2008
    I cleared the cmos through mobo pins, but fans still won't spin.
    I disconnect power to video card and fans spin, but no BIOS POST check.
  • adromil
    adromil Nov 02, 2008
    i just replaced my intel Pentium4 1.5GHz with 3.0GHz
    and my 256MB DDR366 x2 with 1.0GB DDR400 x2
    my board does not beep and it doesn't display anything...
I just had the same problem with the same setup... it was due to bad memory.
I also thought it was a bad video card and swaped one out of a working donor. The issue persisted.
Borrow some ram from a friend or a working system and swap, as a test... this worked for me. running great now.
Good luck
Posted on Jan 10, 2009
Bios is erased, clear cmos thru motherboard; pins
Posted on Apr 05, 2008
Why is power up for intel DQ965CO start up unreliable?
"No bios screen" If you mean that the screen is totally dead with no response at all, but when you power-up you DO hear the normal system beep, then first check your video cable to make sure connections are tight. Take the monitor and plug it into a different computer to make sure that the monitor has failed or not. If the monitor tests good, your case cooling fans and the CPU heatsink fan do spin up, if you do not get the usual system beep when booting, then you have a low-level failure of a component. This could be caused by only one of three things: your CPU (processor) has failed, the motherboard has failed, or possibly there is a problem with the power supply. I hang out at www.suggest-a-fix.com which is a free computer help forum. Post in the Hardware section and I will be along. This forum is not set up for complicated problems that require back-and-forth, in-depth communication.
Jul 27, 2014 | Intel Desktop Board DQ965CO - motherboard...
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
When i press the on switch the computer light turn red color and have a beep sound.
1 or 2 beeps is normal when turning on, for most mobo's. Check the motherboard owners manual for beep errors, for example 3 beeps might be a graphics card error, 4 keyboard error, or CPU or memory. it's in the manual for the specific motherboard. You can get it from the manufacturer's website. I can not supply a link to get you the online manual because you didn't specify what kind of motherboard you are using. Does it still boot? Do you see the BIOS on screen? Any error messages? When you press the power button your computer normally should beep once or twice and then performs a POST... Power-On-Self-Test. and this is when you get any error beeps. It could be something simple like forgot to hook up the monitor, to CPU or memory is loose, or memory is not compatible if you upgraded the memory.
Oct 20, 2009 | HP (350030-001) for Compaq dc7100...
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
POWER
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
EliteGroup P4VXASD2 Motherboard Logo
133 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
