Question about Sony KDS-R50XBR1 50" HDTV
High temp warning
KDS-50xbr1. High temp warning comes up. Says to check vent. Asks if I want to select High Altitude mode. If I leave alone will auto shut down TV with red standby light flashing 2 times..pause...2 times....If I select High altitude mode, TV will stay on indedfinitely? What does the 2 flashes mean?
  • Anonymous Mar 20, 2014
  • 23 Answers
2 BLINKS: Temperature
Posted on Oct 01, 2008
  • 81 Answers
Is the tv in a close compartment ? it also means that no air is circulating
Posted on Apr 05, 2008
SOURCE:
Can the thermistor cause a dryer to shut down in auto mode in about 5 minutes?
Dryer will overheat and shut down if the vent is clogged and the hot air cannot leave the unit. Check for that.
Jun 19, 2017 | Dryers
Sony KDL-V32XBR1 that is giving me a High Temperature Warning
Check the tv is not against a wall and the air vents are not clogged with fluff. A flat screen tv expensive to repair.
Dec 24, 2014 | Sony KDL Televison & Video
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
My Optoma HD 72 flashes green like others have descibed, but if I run it in High Altitude mode it corercts the problem, although it it very noisey. Any ideas to what is causing this issue and how to fix...
sounds like the air flow is restricted and overheats using the regular fan speed.
check for air flow blockages inside and outside, filter problems, etc
Mar 13, 2011 | Optoma HD72 Multimedia Projector
I have a Sony SXRD KDS-R50XBR1 and the tv keeps shutting off and turning back on. While its off the green power light flashes. I just had the lamp replaced and the optical block replaced a few months...
Green light flashing is normal as the lamp warms up before turning on.
If it runs for a bit before turning off it's likely to be overheating somewhere.
Looks to be more than one fan in this so possibly dust in one of the others but there should be a "High Temperature Warning!" message if it's overheating. This set has a "high altitude mode" for extra cooling.
If it turns on and then turns off again instantly it might be something has failed.
There is quite a detailed service manual if you want to have a look for possible clues:
https://www.manualslib.com/manual/817639/Sony-Kds-R50xbr1.html?page=192#manual
Jul 17, 2017 | Sony Televison & Video
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Sony KDS-R50XBR1 50" HDTV Logo
757 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
