Question about GE JTP15 Electric Single Oven
Fan runs for hours after use
If we use our oven to bake something, even for 20 minutes. The fan will run for hours like it's trying to cool the oven down. If I open the door and put my hand inside the after about 20 minutes from turning the oven off it's barely warm. Why does the fan continue to run? Has anyone else had this problem?
Thank you.
Brad
  • TexAskins Apr 05, 2008
    Thanks for the quick response.
    Where is the the sensor for the fan?
    Thanks again.
    Brad
  • Rammot Sep 09, 2008
    Would it be OK to completely take the sensor off and not replace it? Or will that destroy the oven in short period of time?
  • 770 Answers
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
  • Gary Davd
    Gary Davd Apr 05, 2008
    you will need to pull the oven and take off the top plate it is in the middle it is round (dime size) see pic either # 158 or 159
The fan runs when power to the cooker is on but the oven itself is not switched on.
Probably the cooling fan. There is a cabinet thermostat on most ovens these days (Especially wall or underbench models) to keep the cooling fan running after the cooking has finished and oven turned off. This fan will run for a few minutes to cool down the outside of the oven so it doesn't burn / discolour the surrounding cabinet or workbench. If the fan stays on all the time, I would say that the thermostat has probably jammed in the run or on position.
Mar 21, 2017 | Ovens
Why does the cooling fan on the oven continue to run?
Never heard of a cooling fan in an oven.they are usually used for fan baking, which speeds up cooking.
Sep 19, 2014 | Ovens
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
Hobart convexion oven model CN90 . THE FAN MOTOR CUTS OFF AND ON WHEN IT IS IN USE WHAT CAUSE THIS I THOUGHT IT IS SUPPOSE TO RUN ALL THE TIME
No they usually run 2 minutes one way and 2 minutes in opposite direction to even out the baking.
Unless its erratic then something else is wrong.
Feb 17, 2011 | Ovens
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven set to 350F, using type k thermocouple , omega, left reading 370F, right side reading 389F, noticed the cooling fan is not running, baking problems, too ho.
You will not get an even temperature if the circulating fan is not working.
You need to check the fan control circuit and find out why the fan is not coming on, possibly a failed switch relay?
Jan 11, 2010 | GE JKP15 Electric Single Oven
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
GE JTP15 Electric Single Oven Logo
442 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
