Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Posted on Apr 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Graphics cards i have a 3 year old Intel PENTIUM-4 865GV chipset computer . please suggest the best graphics card for me in 5k range
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Apr 06, 2008
Anonymous
Expert
Level 2:
Answers
98
Questions
0
Helped
53206
Points
258
An Nvidia 7600GT AGP 256MB GDDR3 would be a nice card for that motherboard.
What is the "5K range" mean?
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Dell dimention 2350 socket 478 I upgrade celeron 2.0Ghz to pentium 4 3.0Ghz 530 The Bios show me the speed 1.5Ghz. Bios A02
The Dell Dimension 2350 Desktop PC motherboard, has an Intel 845GL motherboard chipset,
mounted to it. (System Information),
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1101572
Here we see that the Intel 845GL chipset supports processors, with a -> maximum <- Front Side Bus of 400MegaHertz, (FSB = 400MHz max.),
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Intel Pentium 4 model 530 (3.0GHz. Also has Hyper-threading Technology. HT), operates with a FSB of 800MegaHertz, (FSB = 800MHz),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
(Scroll down. Pentium 4 HT 530 )
You can't make the Intel 845GL chipset support a processor with an 800MHz FSB.
BIOS update or not, the voltage range will be too low. Therefore the FSB is low. Changing just the Multiplier will not do the trick either.
(BIOS Setup, Advanced Chipset Setup. Doubt the options of changing the FSB, and/or Voltage, and/or Multiplier, is available with that BIOS program))
Note your 3.0GHz processor is operating at 1.5GHz?
Max FSB supported is 400MHz, and your Model 530 needs 800MHz? (For max operation)
Post additional questions in a Comment.
Regards,
joecoolvette
[ Chip and Chipset are shortened terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset technology used for your computer, has a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors )
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
[ The AGP technology, and the PCI-Express technology, is High-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics, is NOT High-speed graphics ]
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to the PCI bus, (Such as a PCI graphics card)
IDE (PATA)
SATA
USB
Ethernet
Audio (Sound)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ CPU stands for Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
So it is first up to the Northbridge chip, of the motherboard chipset, whether it will support a certain processor, THEN if a BIOS update will help.
Hi, I got a new graphic card, GF FX 5500 AGP, 256M, 128B for an old computer, intel pentium 4 1,79 Mh, XP profesional, SP2 and my computer don't boot whit this card. My old graphic card was Nvidia GForce 4...
go back to the old one you are using,maybe your board doesn't support your new graphics card,,i think your new one is agp8x and your board supports on 4x.or maybe you can set it bios to adjust the graphics
2helpful
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    What video card can i buy for my computer ? I have a HP Pavilion a1120n . It already has an internal video card , but i want to upgrade . Its a Intel (R) 82915G / GV / 910GL Express Chipset with 128 mb...
    I suggest you install an AGP video card that suits your requirements. If you play games that require a powerful graphics card, then I recommend the G Force range of graphics cards. A computer shop can recommend to you a graphics card depending upon what programs you are running on your computer. The games programs usually recommends a graphic card with their games.
    Don't forget to disable/turn off the on-board graphics card in the BIOS if you use an external graphics card.
    I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
    hello,,,,,,,,,,,,,
    First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
    I am giving you a configuration in a good budget
    Rs 50,800/-
    Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
    It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
    6helpful
    2answers
    How do I find my graphics card on acer laptop 4720z and change settings to best play games
    * The system configuration of Acer Aspire 4720Z PC Notebook is :
    160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
    * Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
    * But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
    * If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
    * If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
    please rate this advice if it helps...tc! :)
    4helpful
    2answers
    Graphics card for D 101 GGC intel mobo/2.66/p-4/ram 512
    Good news, you can upgrade the graphics card with almost any current PCIe (PCI Express) video card. Once you install a new graphics card in your system, the ATI Radeon x200 will be disabled automatically, as per the manual.
    The one caveat is that the board is not PCIe 2.0 compliant, so any video card that requires PCIe 2.0 compliance will not work. This is not an issue as almost all modern graphics cards work on PCIe 1.0. However, make sure to check the requirements o fthe card before you buy it.
    As for the most suitable graphics card for you, its hard to say without knowing what tasks you wish to use this computer for and what is your budget. If you are only using it for office tasks, then the onboard graphics processor is more than enough for your use.
    I should mention, that the motherboard processor support constrains you to the P4 series of CPUs. This is fine for moderate tasks, but if your gola is to play a game like Crysis, then even the most powerful, multiGPU graphics card will only make the game playable. You will probably never be able to max out your frames per second.
    That said, the board supports up to a 3.4ghz CPU, which is fast enough to play almost every modern game if you upgrade to a powerful graphics card.
    If you wish to do 3D graphics design, I would not recomend upgrading the video card for this purpose. Video rendering and processing stil does rely on the CPU. However, if you look into nvidia's CUDA framekwork, it is possible to offload rendering to the GPU. This is probably not worth the effort unless you are relaly short on cash.
    Bottom line is, yes you can upgrade no problem. As for the best video card, I do need to know he reason you wish to upgrade the video card.
    10helpful
    3answers
    Graphic card for intel (r) 8291g/GV/910GL Express Chipset Family?
    display adapter intel(R) 82915g/GV/910GL Express Chipset Family
    New Graphics card needed
    NVIDIA FX series are very good graphics cards and will run OK on your system
    Top Intel Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
