Question about Palm Treo 650 Handheld
Battery? I recently bought a used 650 and the whole thing keeps turning off. I have to remove/replace the battery to start it up again. Is this a battery problem or something more serious? Luckily I can return it if I choose to. Thanks
  • SDLaRue Apr 29, 2008
    I am having the same exact problem.....its like the phone freezes up. I have contacted the Palm Support team....and after a reset the phone worked fine for a few days and now it has started again. This time a normal warm reset would not do the trick and I had to complete a hard reset. I do not think I should have to reset the phone every few days. And I have not installed any new 3rd party software on the phone....it is at factory settings. I would appreciate all comments
    Novelist:
  • 170 Answers
Have you tried using another battery in the unit?
Does it do the same thing when plugged into an AC power supply?
These phones can be fickle if they've been dropped a few times and contacts are bent or jostled. Sometimes if the housing is twisted physically or stresses are put on the housing it pinches contacts to perform certain actions (I have one that likes to hotsync if the case is twisted).
Check with using the AC pack. If the problem persists, it's the phone. If not, then it's the battery or it's contacts. Try a new battery.
Posted on Apr 29, 2008
SOURCE:
I have a 83 xs650 starts for 2 seconds then shuts down, what is causing this?
I found that with mine. It would start and run for 10/15 seconds and stop. Leave a couple of minutes and start no problem then stop again. Took whole ignition system to Boyer Bransden and they tested it and the brain box was faulty. Replaced that and bingo. SORTED. Over 40 Years Proven Performance
Jun 12, 2014 | 1979 Yamaha XS 650 SF
I recently removed a dead battery from my 2004 Mazda rx8, bought a brand new battery at Canadian tire and then when I tried to start my car it won't turn over,I replaced a relay that was burnt and...
Here’s the thing... Rotary Engines are Very Delicate... I Would Suggest Disconnecting The battery for an hour then try again... or get a jump and let it run... should do the trick
Dec 17, 2017 | 2004 Mazda RX-8
My 2000 Honda Valkyrie won't start. Replaced the battery, replaced the starter button assembly (whole right side switch assembly) with a new part directly from Honda. When I turn the key everything turns...
First check battery connections...
then check Ignition fuse
then check your interlocks...in neutral, sidestand up....kill switch to RUN...also try using clutch in case the neutral switch is not grounding the starter circuit properly.
Apr 01, 2011 | 2000 Honda F6 C Valkyrie
Hi my is a x type 2003 v6 2.5 litre,. Engine will not start, on turning the key a clicking sound comes from the engine.Very frustrating.
The clicking is coing from the starter solenoid.Check terminals are tight and clean.If they are .Remove and replace the starter motor.
Jun 08, 2009 | 2003 Jaguar X-Type
Car has starting problems
Sounds like you are not keeping a charge, you might have to replace the Alt...
Jun 03, 2009 | 1998 Ford Escort
Bike not starting
Sounds l
ike a carb problem
remove air filter take starting fluid and spray in carb as you try to start it
keep spraying to keep it going
If it runs as long as you spray into carb
you will need to have the carb worked on
Jan 06, 2009 | 2005 Suzuki SV 650 S
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Palm treo 650
You can do a soft reset by pressing the small indented button on the back with your stylus,: or you can do a hard reset by removing the battery and pressing the same button on the rear with your stylus. I would try the soft reset first, as the hard reset wipes all your data.
Jan 05, 2008 | Palm Treo 650 Handheld
Reseting the whole console.
Remove the battery cover off the back of the unit. (One small Philips screw.)
Remove the battery.
Leave the system without the battery for 10-15 minutes.
Replace the battery.
Re-install the battery cover.
Dec 20, 2007 | Nintendo DS Lite Console
Palm Treo 650 Handheld Logo
309 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
