Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 54" where are they located, what about the power, after unpluged. Thanks
  • Philips Master
  • 8,617 Answers
They are located on the board on the left side on the large heat sink they are secured with screws or a spring bar release the bar and you can see the numbers they should be STK392-120 some times they have the cheaper STK392-110 but the 120s are better quality.The power after being unplugged wont be an issue just dont touch the back side of the circuits where the capacitors are located. heres apicture of what they look like and where they are located.magnavox 54
Posted on Apr 05, 2008
SOURCE:
I HAD A POWER OUTAGE AND NOW MY MAGNAVOX DVD WON'T TURN ON, PLEASE AND THANKS
Unplug it for about 10 minutes. Plug it back in and see if that helps. If not then there must have been a power surge when power was restored in your home.
Dec 05, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox 54" Projection screen TV
Replace your STKs 392-110s with 180s if 020s go with 040s
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 54
You can get new ones at the following link. You need two STK392-120 ICs for that model. The site provides free step by step instructions with the IC order and also sets you up with a free email and instant message so you can chat with a tech during the repair if you need too. Heres the link to the site.
http://servicemanuals.vstore.ca/
Apr 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Shut off and won't turn back on
try unplugging the set from the wall for 1 min and then plug it and try power button
Nov 12, 2007 | Philips Magnavox MS3652S 36" TV
Magnavox model TS2768C101
Requires troubleshoot,locate and replace bad caps in horiz
drive circuit. Usually 47mf/25v..................+ solder any/all
bad connects = prevent maintenance................T.
Nov 04, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
