Question about Bosch 23 in. SHU33A Built-In Dishwasher
Not cleaning dishes
Our bosch SHU33A was brand new when we moved into our condo about a year ago. it has worked great until recently. now, it goes through an entire cycle, but when i open the door...i see that the soap door has opened, but it appears as though the detergent just slid out all over my silverware and the bottom of the dishwasher. and the dishes are not clean. what's the deal?
  • Anonymous Jun 01, 2008
    We had the same problem. I solved it by poping the sliding soap cover off and scraping the excess soap off. Be careful not to pop the spring off because it's tough to get back on.
    Hope this helps.
  • tvoperator Dec 28, 2008
    My SHU33A is not getting any water when I run the regular wash.
  • 725 Answers
Sounds like you are not getting enough or any water a check the water level when it fills... let me know
Posted on Apr 05, 2008
Washer Drum Not Moving- belt is fine
Brand new belt and no other symptoms; my bet is the motor brushes. You will have to remove the motor to check this. there are 2 holders for the spring-loaded brush. I am guessing they are worn down and just stopped touching. It's a "silent failure" with no real symptoms except is doesn't move.
May 26, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
We have a Bosch shu33 it started running a longer cycle& no longer shows the sanitized light
I got answer from previous post on your site by 'boeschbrady'.Person had same problem,also said part was under Warranty. we called the store where unit was purchased and my unit is also under Warranty "less than 5 years old' repair man is coming next week.Thank you for a
great site Patee
Jan 11, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Hotpoint GE Household Microwave
Well, I think you should get a brand new one.
They do not cost as much to replace these days and it might be safer.
May 11, 2017 | GE Microwave Ovens
Wont drain check everything push drain botton still wont drain
i call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
May 18, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch SHU33A won't drain
I believe you, but did you check the nipple on the drain where the hose connects?
My sink drained OK, and when I took the dishwasher hose loose from the sinkdrain it drained great into a bucket.
When I stuck a screwdriver down where the drainhose connects to the sinkdrain, I felt all kinds of resistance. Its now cleaned out and the dishwasher drains again.
Hope this is your problem otherwise you may need a new pump.
Apr 07, 2008 | Dishwashers
Broken dishwasher
I have a kenmore model 665 168 29000 the mounting bracket have broken from under the cabinet, so when you open the door and pull the racks out the machine moves forward, how can i fix this?????
Mar 08, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
483 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
