Question about Toshiba 50H13 50" Rear Projection Television
Thank you for the help
I had alot of the tv taken apart until I realized that the IC chips are buried in between alot of scary stuff. I know when to say no.
I read someware that there is a place that will replace my chips if I send them the whole board? Or they will swap mine with another?
I could take that board out and put a new one in., Just not comfy with unsoldering tons o stuff.
Any suggestions?
  • Toshiba Master
  • 8,617 Answers
Youre looking at a charge of about 350 to 400 dollars for that repair. The site I posted rebuilds boards. Leave an email and request a quote its sure to be cheaper than a local repair shop.
Posted on Apr 05, 2008
Need to replace Mother Board IC chips on a Acer Aspire 7736Z
To remove the chips, gently heat the exposed legs of the IC with a soldering iron and desoldering wick. When you have removed most of the solder, you will be able to pop the chips off the board. To apply the new chips, see this video on Youtube
Apr 21, 2017 | Acer Aspire 7736z Genuine 17.3" Laptop...
Nothing lights on the tv at all? Even the LED power indicator? Might have taken a power surge/hit. Chances are it popped a capacitor on the power supply or logic board. Nothing short of a actual electronics or tv repqair shop is going to help you unfortunateley. Unless you know how to look at circuit boards and are comfortable taking apart the tv while unplugged of course) but be careful becase the power supply can still carry a lethal charge on it if you are not careful. If you know somone who knows circuitboards and can solder and unsolder then you might get licky if it's a capacitor or a resistor. If it's a IC chip though you are going to have to buy a board or a powersupply. So again you really need to find a local tv repair shop.
May 16, 2011 | Televison & Video
Problem is only with snapping the picture. The screen started out being blurred only AFTER the photo was taken. Now the entire screen is black (no image) after the photo is taken. It just started the...
It is known problem of ccd imager chip failure in DSC-T1 camera, ccd imager chip will be replace to get correct live view in camera mode to take fresh pictures.
Local camera repair shop will do this job because camera will take apart, let me know to provide you part number info if you are handy with electronics stuff repair and willing to replace ccd imager chip.
Hope this will help.
Mar 17, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures when taken look green in areas
This is problem of bad ccd imager chip in DSC-T33 that generates greenish distorted image in camera.
Replace ccd imager chip in camera to solve this issue.
If you are handy with electronics stuff repair and can take apart this camera easily with proper tools then let me know to provide you ccd imager chip part number.
Nov 04, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
I inherited a braun 4169 immersion blender and it seems that the previous owner did not realize it could be taken apart for cleaning! it is totally stuck together- how can i take it apart properly? I've...
see my solution, posted today, 3rd Sept 2010. if you are not pretty handy at fixing things then don't bother is my advice because even if you manage to get it working ok it still my be unusable.
Sep 01, 2010 | Robot Coupe MP450 Handheld Blender
My 1080i has a triple picture, can you help?
It definitely can be fixed the IC chips (called STKs) that line up the images from each picture tube are failing.Sometimes a fuse or resistor go out along with the chips. The parts would cost around $100 + whatever labor charge if you hire someone.
Apr 29, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Look for the STK ICs mounted on 2 big heatsinks.
I would suggest to replace both of them once you have the TV taken apart.
I think the part markings are STK392-040.
Let me know if you need further assistance.
Apr 29, 2008 | Philips 60PP9352 60" Rear Projection...
Only Horizontal line
If you can hit it, it is probabl;y just bad solder joints on the vertilcal output IC (yes thats right vertical, because it stretches,or in your case compresses the picture vertically). kind of hard to point you to it if you've never been in a tv but it will be a little chip standing up mounted onto a piece of metal (heat sinc). There will be a few though the IC will likely have 1 row of pins maybe 7-10. And probably have a part number on it that begins with "LA" like maybe LA7838. You can tap around the different heat syncs with a NON-METALIC with the TV on until you find the one that is sensitive that should help you identify the vertical IC. Any way unplu flip the PCB over and resolder that IC. That should take care of it.
Dec 28, 2007 | Televison & Video
Toshiba 50H13 50" Rear Projection Television Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
