Question about Combi Centre DX - Mango
Worcester combi 28si II
Boiler fires up ok then cuts out after a couple of mins.the red light on the gas starts to flash.the preasures fine,and ive checked the pump seems to be working ok.might be thermostat problem,can you help.
  • Anonymous Apr 19, 2008
    I have a malvern combi.It locks out only after 15 seconds.Steps taken so far includes changing control panel ,sequence controller,modreg control board,ch sensor,overheat thermostat,flu stat,pump overrun stat,overheat stat,ch sensor and combi valve and ignition,air pressure swith----Problem still exists-any suggestions
  • ghaffer99 Apr 20, 2008
    i have the same problum with . worcester boiler 28si ii cuts off warning light flashing.. have to leave for while to reset .. any one know the problum?
New boiler?
Posted on May 07, 2008
  • oatcakekid Dec 06, 2010
    Could be flame sensor. Do you have a manual?
Combi -boiler tripped out by shower use
Look for a red reset button to press, maybe on top of casing or inside front panel
Mar 04, 2014 | Home
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
I have worcester combi boiler 24CDI RSF, the boiler will not ignite, for the hot water or the central heating, it was working ok, and the red water light is flashing
i think the fan may be stuck. you will need to gain access to the internals of the boiler so a gas safe engineer will need to be employed to do it. if it is the fan, a simple squirt of lubricant will free it and give you anything from a week to a year of trouble free operation but! you will need to get a new fan. Fit a new one as soon as you can as they tend to go at the worst possible time if you dont
Oct 20, 2011 | Combi Centre DX - Mango
My worcester 240 combi boiler. when heating goes on after few mins it starts to go off and on at the boiler with a clicking sound, and boiler kicks in to light up and go off at same time. any help please
check the water pressure on the combi could be low or in the back of your manuel there is a fault finding guide which is very good and simple to follow .
Oct 02, 2010 | Heating & Cooling
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
Flashing red light under ! on my worcester 24i junior combi boiler and pressure under 1
you don't have enough pressure in the tank you are using, needs to be a 2lb system to work properly it is starving the gas valve for gas
Apr 19, 2009 | Water Heaters
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Combi Centre DX - Mango Logo
1,816 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
