Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
My computer has ceased to recognize the drive.
When I turn the drive on, the blue power light comes on but computer does not recognize it. The idicator does not pulse with a different color to indicate activity.
  • 5 more comments
  • Anonymous Apr 17, 2008
    I have the same problem with the acomdata 320gb drive. It worked once I did a sve and when I tried to do another save 2 weeks later it has never worked again solid blue light my pc wont recognize it exists.
  • Reddawgz May 14, 2008
    I am having the same problem with my external hard drive. Is there any way to retrieve the data from the hard drive?
  • Blackoutmiam May 14, 2008
    im having the very same problems... My hard drive is not showing up on my computer anymore...
  • Anonymous May 26, 2008
    IT sucks dont but anymore stuff from Acomdata
  • strapp Jun 05, 2008
    Our computer does not recognize the hard drive. The blue light comes on as well as a flashing red light with a beep. Sounds like a faint clicking as well.
  • caveboy2000 Jul 12, 2008
    Same problem tonight! I panicked. No backup. Same soft click and blue light.
    So, after many attempts at startup, I decided to open the drive case and remove the drive.
    I placed it in another generic (firewire/usb) case. I hooked it up, plugged in the firewire cable, and it worked!
    The Acomdata case failed - not the drive!
  • jackof Jul 13, 2008
    Exactly the same problem - all of a sudden - solid blue light and the computer doesn't recognize it.
I had the same problem with my iomega 320 external hard drive. The Hard drive is a seagate and I believe that the controller was made by Acomdata based on the number on the circuit board.
When my drive stop working I could here the drive still spinning when power was on.
I asked one of the tech guys at Fry's Electronics and he suggested that the board was bad and I replaced the enclosure (which comes with it's own controller card).
I took the drive out of the iomega enclosure and installed it into a new kingwin enclosure ($25.00usd @ fry's) and that took care of the problem.
I picked the Kingwin because it has pretty blue and orange leds. I do believe that a cheaper enclosure would do fine and I have seen them on the net for under $10.
I have looked for a replacement card, but they seem to be quite expensive .
Posted on May 19, 2008
  • 6976pam Dec 12, 2010
    how do you know which replacement enclosure to buy ? I just want my pictures :-(
This is cont. from my post on the previous issue.
I went as far as reloading windows on my pc to see if the problem was my pc did not help.
I now have a 500GB exteranl hard drive the pc is working fine with it so I know the problem is in the acomdata drive.
I think the key is a different manufacturer it so far is working fine.
I am bummed out the acomdata only lasted about 2 to 3 weeks before I had a problem or noticed i had a problem. Should I try to format the drive would this help?
Posted on Apr 17, 2008
SOURCE:
My hard drive is not recognized in my mac. The light is blue, neve turns to green
Have you tried to connect the drive to a different computer? You can also try to open Disk Utility (use spotlight search to find it). My guess is it doesn't show up there which means there is a problem with the Buffalo device. The disk is most likely fine, just the Buffalo casing needs to be replaced.
Apr 23, 2014 | Buffalo Technology Buffalo 1TB MiniStation...
When I plug my HD in, the blue light comes on, but the motor isnt running.
Have you plugged in the AC power adapter? The blue light means it is connected to the computer but USB power is not enough to operate this drive.
Mar 25, 2014 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Brian
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Wont recognize drive
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 19, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Worked fine for a year, now not recognized or functioning
I had the same issue- light was blinking from red to blue, could not get my computers (I have a Mac and a PC) to recognize the drive, sounded like the drive wasn't powering up...
I replaced the Acom drive enclosure with a new one (CP Technologies). I don't know if the drive enclosure or power supply was at fault-- but it wasn't the internal drive. Plugged it in and amazingly all my data was back. For thirty bucks it was far less than sending out the drive to a 'data recovery' expert!
Jun 09, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Computer does not recognize the external harddrive
try installing the drivers on your computer for it from this website
http://list.driverguide.com/matches.php?h=932a9713352aa24ea0444960cf489ad2&ids[0]=1119263&ids[1]=1119260&ids[2]=1119267&cid=1256&model=HD160UE5-72 - E5 - 160GB
May 23, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
you should check that the connecting cables are connected properly to the mother board.
May 13, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Open Questions:
FSECURE toll free phone +$&{[email protected]*1O69} NuMbEr USA .Anita This FSECURE USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 FSECURE USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the FSECURE USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, FSECURE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. FSECURE USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact FSECURE USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling FSECURE USA Calling FSECURE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from FSECURE USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with FSECURE USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare FSECURE USA's phone numbers against each other. Contacting FSECURE USA in General While I8OO8O31O69 is FSECURE USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach FSECURE USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact FSECURE USA.Anita
Oct 17, 2019 | Best Computers & Internet
NORTON toll free phone +$&{[email protected]*1O69} NuMbEr USA This NORTON USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 NORTON USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the NORTON USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, NORTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON USA Calling NORTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON USA's phone numbers against each other. Contacting NORTON USA in General While I8OO8O31O69 is NORTON USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON USA.Anita
Oct 17, 2019 | Norton Computers & Internet
ZONEALARM toll free phone +$&{[email protected]*1O69} NuMbEr USA .Anita This ZONEALARM USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ZONEALARM USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ZONEALARM USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, ZONEALARM USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ZONEALARM USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ZONEALARM USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ZONEALARM USA Calling ZONEALARM USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ZONEALARM USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ZONEALARM USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ZONEALARM USA's phone numbers against each other. Contacting ZONEALARM USA in General While I8OO8O31O69 is ZONEALARM USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ZONEALARM USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ZONEALARM USA.Anita
MCAFEE toll free phone +$&{[email protected]*1O69} NuMbEr USA This MCAFEE USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 MCAFEE USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the MCAFEE USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.Anita
Oct 17, 2019 | Mcafee Computers & Internet
See all Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Questions
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
602 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
